can i swap 98 tacoma springs to my 93 t100?
Old 04-13-2015, 06:12 PM
nanner's Avatar
I am in need of leaf springs for my 93 t100 4x4 regular cab and i have heard rumor that the 98 tacoma leaf springs will fit im looking for someone who knows if i can do this swap without serious modifications like driveshaft adjustments i want the tacoma springs because they are cheaper and have 4 leafs instead of the 3 leaf replacement springs for the t100 any input or help is appreciated thank you
Old 04-14-2015, 12:06 AM
wyoming9's Avatar
Red face
Most spring companies have the spring dimensions on the web sites it should be simple to compare measurements .
I only ever worked on one T100 about the only thing in common with my Tacoma was the engine.
Every thing else was unique to the T100 because of it being so different.
Looks like they would work with just moving the spring hanger to adjust for the different length.
This is what I see by looking at General Springs website.
Like any other fabrication it just depends how much $$$ and time you want to spend
Old 04-14-2015, 03:33 AM
nanner's Avatar
Thank you for your input i think im gonna go with the direct fit springs for the t100 i need springs asap the truck is my work truck and i cant load it down like i need to so i want a hassle free install what do you think about the add a leaf kits? Would that be an effective method to beef up the springs later?
Old 04-14-2015, 11:09 AM
wyoming9's Avatar
Red face
I run Super Springs on my Tacoma I love them best investment I ever made
I have had up to a Ton in the bed not something I would do ever day .
800 to 1200 pounds almost every time I haul stuff it is a work Truck
Ton of wood bricks
They do make them for the T100
Old 04-14-2015, 11:14 AM
scope103's Avatar
Originally Posted by nanner
... the truck is my work truck and i cant load it down like i need to ...
The T100 is a "1/2 Ton truck." It's not just the springs; it's the brakes, the steering, the transmission, the frame, etc. If you get in an accident carrying more than the manufacturer okays, you'll be in a heap of trouble, no matter what you do to the springs. Particularly if you're carrying that load as part of your work!
If you actually need to carry more than your T100 is designed for, you should consider getting a truck that can do it.
Old 04-14-2015, 11:25 AM
nanner's Avatar
Im not hauling anything crazy ever really just want a decent suspension since mine is broken where can i order the super springs?
Old 04-15-2015, 12:04 AM
wyoming9's Avatar
Red face
Just use the search Engine of your choice Super Springs .
They have a very helpful Website.
If I go by my empty weight and the GVW I can carry 1500 pound payload and still not exceed my GVW.
Then if I remove all the tools and welding cable I can add another 400 pounds
Old 04-15-2015, 02:45 AM
nanner's Avatar
I found the website thank you very much for your help
Old 04-15-2015, 10:13 AM
wyoming9's Avatar
Red face
Your very welcome!!!
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
jgwerth
07-16-2015 03:23 PM
taller1
07-16-2015 03:00 PM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: can i swap 98 tacoma springs to my 93 t100?
