Can I disable/remove my rear ABS?
Old 02-06-2006, 12:12 AM
Mikronized's Avatar
I'm getting ready to do an elocker swap on my runner and I need to know what to do about the rear abs sensor on my 3rd.
Can I just unplug it, and if so does that mess up my braking? or is there a way to turn off the abs system?
thanks!
Old 02-06-2006, 06:50 AM
4runnermax's Avatar
Well i dont know much about 4runners specifically yet, but in most cars unplugging the abs fuse disables it safely, I dont know why you would have any problem.
Old 02-06-2006, 07:37 AM
Brendan's Avatar
mine has been disconnected since i swapped thirds and no problem whatsoever other than the rear ABS light always being on, on the dash. if you are ever issued a vehicle inspection though, your vehicle will not pass if the ABS has been disabled.
Old 02-06-2006, 09:16 AM
Robinhood150's Avatar
Ditto. I pulled the fuse too, though.
Old 02-06-2006, 10:05 AM
4x4Lamm's Avatar
MY manual from my 92 4Runner says when you shift into 4WD ABS is automaticly defeated. Not sure if that helps.
Lamm
Old 02-06-2006, 02:42 PM
UKMyers's Avatar
When I had my 4.88's put in the mechanic broke off my ABS sensor in the hole in the 3rd. My ABS light was on until I plugged in the sensor that I pulled from a junkyard. I could'nt get the broke off piece out so now the new sensor is bolted upside down where the original one is awaiting the day that I have the 3rd apart again so I can get that broken off piece out of the housing. You should be able to just leave it all hooked up and zip tie it out the way someplace. As long as it's plugged into the harness it won't cause the light the come on even if it's not even in the third.
Old 02-06-2006, 03:20 PM
Brendan's Avatar
i'm not understanding.... how do i make it so my ABS light is off?
Old 02-06-2006, 03:55 PM
Flamedx4's Avatar
Incorrectimundo! The ABS brain looks for a signal from that sensor and when it's not getting one - turns on the light.
Changed my gears - light is on.
Disconnected the sensor - light stays on.
I unplugged the ABS plug on the ABS unit (rf frame rail below batterry) - light stays on.
I unplugged my ABS fuse. Light stays on. (mildly surprised me, but when I looked at the diagram I see why - the light is ON by default - the ECU has to turn it OFF)
Interesting thing - a bulb like the high beam indicator which is rarely on, burns out on a regular basis. The @#$&* ABS light has been on for years - you would think it would have burned out by now. (You would also think each time I take the dash apart I would remember to pull out the bulb.. but NOOO...)
Old 02-06-2006, 03:58 PM
Flamedx4's Avatar
thanks!
It will not mess up your braking. ABS is passive. (unless you get traction control with it, then it's not passive - it's INTRUSIVE!) 99% of us will drive our entire lives and never have ABS kick in at all. The brakes work entirely normal without it.
Old 02-06-2006, 04:05 PM
Mikronized's Avatar
I unplugged my ABS fuse. Light stays on. (mildly surprised me)
interesting... rockota on pirate said this :
Yes, it's not that hard and you don't have to remove the bulb. Follow the wires from the rear to under the hood. You should see two controllers on the pass side engine compartment - just remove them, IIRC, and you'll be set. It's been about 4 years, so don't quote me, but I know it's not hard at all.
okamikai
04-30-2018 10:19 PM
SMOD
07-27-2015 01:45 PM
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
87turboPA
07-12-2015 07:49 AM
Quick Reply: Can I disable/remove my rear ABS?
