Can I bolt in??
Old Nov 16, 2007 | 12:15 AM
kylenbeck's Avatar
Smile Can I bolt in??
I was hearing something about being able to bolt in a 86 Celica engine into my 1988 4 runner i have a 22re engine in now. I have a 5 speed manual tranny. Will this engine bolt up to my tranny and if not what other engine will??? Please help i need to find a different power plant for my runner as i have Drowned my existing one by accident!!!Any comments or ideas welcome!!!
Old Nov 16, 2007 | 12:33 AM
ozziesironmanoffroad's Avatar
isnt the 86 celica engine the 22re? if you want power, get the engine out of a supra V6/Straight6 turbo.
Old Nov 16, 2007 | 04:18 AM
MMA_Alex's Avatar
yeah, i'm pretty sure the 6 celicas used either 22r's, or 22re's
Old Nov 16, 2007 | 04:52 AM
bigt's Avatar
yes i had a 86 celicia gt and it was a 22re same as all 3 of my 4runners have been
Old Nov 16, 2007 | 05:02 AM
waskillywabbit's Avatar
Motor mounts will be different so you will have to swap them. I know several folks who have put in a Celica 22R to replace theirs that was dead in the 4Runner. Personally I wouldnt have a carbed engine.
Old Nov 16, 2007 | 01:13 PM
anotherjeff's Avatar
ANY '85 - '95 22R/RE engine (including head and cam) will interchange.
Old Nov 17, 2007 | 11:10 PM
kylenbeck's Avatar
Ok then will the Supra v6 fit in easy into the 4 runner??? i want to stay away from turbo since my truck likes to swin and i dont think the turbo would stand up to water too well!!
Old Nov 17, 2007 | 11:16 PM
98sr5tacoma's Avatar
I6
I6
I6
are you doin this swap yourself
Old Nov 17, 2007 | 11:34 PM
apalmer1's Avatar
Theres a couple people who have put 7MGE's in their 4runners (86.5-98 supra 3.0L I6) and one guy i know of who put in a 2JZ-GTE (MKIV surpa) The 7M swap isnt too hard supposedly but then again what engine swap can you honestly consider easy?
Old Nov 18, 2007 | 02:36 AM
ovrrdrive's Avatar
The supra engine is not a direct swap in. It's not as bad as a chevy v8 or ford v8 swap, but there is a ton of work and prep that has to be done. Do your homework...
Old Nov 18, 2007 | 08:36 AM
DeathCougar's Avatar
Cmon guys, lots of incorrect info here.
let me set the record straight.
The 86 celica is FWD, not RWD. It uses the 2S-FE engine found in the camrys. Its a one year only engine for the celica, they switched to the 3S-FE in 87.
the last year for the 22RE in the celicas was 1985. This engine CAN be used, but you will have to swap motor mounts, oil pan, wiring, injectors, etc.
Supras do not have a V6, they are an inline 6. Depending on the production date and body style of the 86, it will have the 2.8L 5MGE, or thee 3.0L 7MGE.
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
