can I accomplish this?
Old 10-13-2012, 06:52 AM
fairfaxlineman's Avatar
I have a 87 pickup. When I start the truck it idles great and runs decent. until it starts to warm up, then it gets progressivly worse until I can almost not drive at all. It pops and misses and backfires under load but revs fine in neutral. then once it is warm it idles rough and just about dies. after searching this forum, I think I need to replace the injectors. The ? is how hard is it to remove the injectors. I have fixed alot of things in the past on several vehicles but dont know about this. also what else should I check before trying this? truck has 160,000 miles. probably need to have injectors cleaned anyways.
Old 10-13-2012, 06:57 AM
scope103's Avatar
Have you checked ignition timing? It can cause those symptoms, and it's a lot easier to check than getting to the injectors. (And I'm not even going to ask whether you've checked for codes.)
Old 10-13-2012, 07:10 AM
I am not proud. I dont know how to check the ignition timing? I also dont know how to check codes? If anyone would take time to explain it to me I would really appreciate it.
Old 10-13-2012, 07:21 AM
also, I dont know if this ia a factor but i drove in a rain storm to get to work and when i left work the problem started. could be a coincedence but just wanted to put it out there.
Old 10-13-2012, 07:26 AM
warbirdghost's Avatar
This sounds stupid and I don't want to sound lazy;you may have some big problems with your rig but I picked up a 86EFI for $300 for a parts truck because the kid told me the engine was blown. I towed it home, replaced the battery and terminals and it fired up. It ran awful and I didn't want to put any money into it as I was still building my 85 so I dumped a can of seafoam in the oil and fuel tank. It ran really good. eventually the timing chain went bad so I'm replacing that this weekend. So I would toss in a can of seafoam. If it doesn't do anything you're only out ten bucks and no labor.
Old 10-13-2012, 07:29 AM
Just read you're last post. Check to see if you have any exposed wires that may have been effected by the moisture...or vacuum lines. I'm not an EFI guy so I'm just throwing some dumb guesses out that I would try first If I was you
Old 10-13-2012, 08:08 AM
scope103's Avatar
Everybody has to start somewhere. But if you don't know how to check for codes (or timing), replacing injectors will be quite a challenge. More so because you don't have enough knowledge (yet) to diagnose whether that's the problem at all. (While a lot of us have benefited from cleaning injectors, it's not a "maintenance item", and you'll do well to eliminate a lot of other causes first.)
Start with perusing the manual. http://www.ncttora.com/fsm/1990-1995...es/repair.html (this one isn't for an '87, but is easy to access. You can download the correct manual here: http://www.ncttora.com/fsm/, but it's all one piece.)
Continue with www.autoshop101.com. Not too basic, and very Toyota focussed.
Good luck, and welcome to Yotatech.
Old 10-13-2012, 08:18 AM
thanks for you help. this forum is great!!!
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
ia02
08-20-2015 11:04 AM
priest16
15
08-06-2015 07:43 AM
Numberonedad6
07-30-2015 07:10 PM
Quick Reply: can I accomplish this?
