A/C not blowing air
Old 08-20-2012, 03:57 PM
PR_TRUCK's Avatar
A/C not blowing air
Hello guys, my A/C stop blowing air. One guy mention it could be the compressor, other said is the blower. I think is the blower because I here the compressor running. How i can diagnose this before going to a mechanic and he tells everything is screw?
thanks in advance
Old 08-20-2012, 07:30 PM
rworegon's Avatar
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml
Old 08-20-2012, 07:36 PM
Discombobulated's Avatar
Fuses? If all the fuses are good I would point to the blower motor. Start with those then get into the can of worms.
Old 08-20-2012, 07:39 PM
rworegon's Avatar
Another easy one would be a loose electrical connection at the blower.
Old 08-21-2012, 08:36 PM
kuzbro's Avatar
With the engine running, have someone turn on the AC and see if the (electric)clutch engages. I'm not that familiar with Toyota's yet, but a common sign of low freon is a short cycling compressor. If the compressor is working properly (with a good charge) the suction line should be cool to touch and you'll see condensation on same.
Old 08-21-2012, 09:56 PM
RAD4Runner's Avatar
Fuses, Switch, Component Location - 1986 MoreFunner
Originally Posted by PR_TRUCK
Stop blowing air. One guy mention it could be the compressor, other said is the blower. I think is the blower because I here the compressor running. How i can diagnose this before going to a mechanic and he tells everything is screw?
Good move asking the forum before trusting your truck to those you should not trust!
You said "stopped blowing" so you mean it does not blow air from the vents, right? If so, then it's a problem with the blower circuit, that 4crawler covers on his website, not the compressor (Blower does the blowing of air, compressor does the compressing of refrigerant that produces the cooling process.)
Blower relay and fuses for blower (blowing air) and air-conditioning (cooling air) are in dash, behind the cigarette lighter jack and to left of glove box
Schematic with notes on what you could quickly check without taking things apart is here:
Album URL: http://photobucket.com/rad4runner_hvac
Best of luck.
Old 08-06-2017, 09:35 AM
msucoggy's Avatar
fixed
thanks in advance
i follower the pics posted...thanks so much...suspected issue was behind dash/glovebox...fuses under hood good...connections good...pulled out vent filter (had no idea it was there but it was nasty)...checked ac on and off...nada...finally used a pen to push on the fanblade and boom...fan blowing again. apparently the garbage on the filter fell into fan so hung it up. thanks! the 103 degree tx heat w no a/c has suuuucked
Old 08-14-2017, 07:43 AM
scope103's Avatar
... Blower relay and fuses for blower (blowing air) and air-conditioning (cooling air) are in dash, behind the cigarette lighter jack and to left of glove box
Hmmm. Looks like they are on the other side (closer to the right door -- ignore the dyslexic caption in the photo) in my '94.
MO transplant
04-23-2023 11:58 AM
mussy01
12-13-2016 08:20 PM
Tacoma1313
08-17-2015 05:44 PM
klavender1
08-15-2015 01:51 PM
jackiebrownia
07-20-2015 09:02 AM
Quick Reply: A/C not blowing air
