brake lock up when engaging 4wd
Old 03-25-2010, 04:27 PM
john73bgt's Avatar
recently had a fender bender that bent the back axles on both side. Insurance replace them and found nothing else wrong. Haven't 4wd for a while and tried to put into gear today. Fortunately I was sitting on the side of the road when I put it into 4wd. Tried to take off and suddenly found the rear end brakes locking up as I tried to go. Backed up slowly and then tried again. Again it locked up. Took is out of 4wd and every thing acts normal.
Anybody out there have any ideas?
Old 03-25-2010, 04:28 PM
toyota4x4907's Avatar
How do you know its the rear?
Old 03-25-2010, 04:33 PM
john73bgt's Avatar
not really sure other than hearing the rear tires squeal as the front pull it forward/
Old 03-25-2010, 04:48 PM
yotaman85's Avatar
its not locking up the breaks, the rear axle they replaced the bent one with has the wrong gears in it. your getting drive train bind. try putting the truck on a lift and seeing if the wheels will turn in 4wd. other wise check to see if your e-brake line somehow got mixed in with the transfer case linkage.
Old 03-25-2010, 04:51 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
ding!
Old 03-25-2010, 04:56 PM
yotaman85's Avatar
if the rear tires are dragging and not pushing it means the rear axle has lower gears then the front.. have them replace the front if you can.. lower gears on their dime..
Old 03-25-2010, 05:02 PM
Marc's Avatar
When checking on the lift, mark the front and rear tires with a grease pen and see if they are rotating at the same speed. (as others have said they probably won't be).
Old 10-03-2010, 06:03 PM
thisgsx's Avatar
sorry to bring this back, but mine is also doing the same thing. so pretty much all i have to do is replace the front axles with the correct gears? how do you know if you've bought the correct set?
Old 10-03-2010, 06:17 PM
Teuf's Avatar
There is a formula for turning the tires and watching the drive shaft. I am sure some who has the link will chime in.
Old 10-03-2010, 06:57 PM
chuntr's Avatar
you replace the front differential gears, not the axles. (or the rear, depending).
info on identifying what gears you have: https://www.yotatech.com/forums/f116...osting-204178/
Old 10-03-2010, 07:06 PM
thisgsx's Avatar
thanks guys.
thisgsx's Avatar
im interested in this. i'll wait and see if anyone will chime in.
06-01-2021 01:51 PM
adammtb
07-27-2015 11:57 AM
MTLroadierunner
07-20-2015 03:07 PM
jgwerth
07-16-2015 03:23 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: brake lock up when engaging 4wd
