blown headgasket - parts advice
Old Sep 4, 2008 | 07:25 PM
sh0kk86's Avatar
well unfortunately my 86 22r blew its first hg, at just under 185k(most likely more, the odo is off because of the bigger tires)
I dont want to get a new head, rebuild the head because i fear that to much compression will f*(& up the bottom end of this tired motor.
i was keeping a list of parts today while trying to pull the head.
Headgasket
Head Bolts $25 from engn bldr
timing chain kit(since im doing hg, might as well) $50 from engnbldr
fuel pump
fuel filter
water pump(should i replace this? im assuming its stock)
valve cover gasket(its only a couple months old, but when i pulled the cover it is ripped in 2 places, wasnt leaking but should be replaced probably
exhaust manifold gasket
thermostat(was having overheating problems)
https://www.1sttoyotaparts.com/partscat.html
these are all toyota parts right, and not just cheap aftermarket parts that "fit Toyota"
also, anyone have advice on getting the exhaust manifold away from the exhaust? i cant loosen the 3 nuts holding it together.
thanks yt
Old Sep 5, 2008 | 05:48 AM
TNRabbit's Avatar
Here's three good links for TONS of info:
https://www.yotatech.com/forums/f116/crap-head-gasket-giving-up-ghost-108156/"]https://www.yotatech.com/forums/f116/crap-head-gasket-giving-up-ghost-108156/
https://www.yotatech.com/forums/f116/pics-my-hg-replacement-sloooow-going-88538/"]
https://www.yotatech.com/forums/f116...et-job-104934/
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
skoti89
Jul 8, 2015 12:05 AM
Vargntucson
Jul 4, 2015 12:15 PM
