Old 03-30-2016, 03:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Steering & Suspension Guides
Print Wikipost
bleeding the power steering system??
Old 03-19-2009, 03:30 PM
aquaholic's Avatar
i just rebuilt my power steering pump (resealed really) and now the dam thing doesn't have ps unless the engine is really revving. i am attributing this to air in the system since i resealed the pump. anyone know how to bleed the air out of the power steering system 0n a 96 runner v6?
Old 03-19-2009, 03:36 PM
aquaholic's Avatar
anyone?
Old 03-19-2009, 04:22 PM
T-1000's Avatar
Use search! It took me literally 30 seconds to find this:
https://www.yotatech.com/forums/f116...tion-s-151870/
Old 03-19-2009, 05:01 PM
aquaholic's Avatar
i saw that thread but it doesn't explain how to bleed the pump. its geared more towards how to bleed the rear antilock system using that bazillion dollar dealership tool. my issue is with the pump itself and not so much with the rear antilocks that are indirectly tied into the ps pump system.
Old 03-19-2009, 05:14 PM
space-junk's Avatar
the pump should bleed itself with a few lock to lock turns...
just crank the wheels, check the level, add ATF, repeat until full...
Old 03-19-2009, 05:22 PM
T-1000's Avatar
It's the same.
http://www.ncttora.com/fsm/1990-1995...e/onvehicl.pdf
That's all you need right there.
Old 03-20-2009, 07:19 PM
aquaholic's Avatar
yeah i'm a loser. my problem was i reversed the two hoses that hook to the bottom/side of the pump. i switched them and all is ok.
Old 03-21-2009, 01:21 AM
space-junk's Avatar
glad you figured it out!
btw, welcome to YotaTech...
Old 03-21-2009, 01:24 AM
abecedarian's Avatar
You're only a loser if you don't figure it out.
(Which makes me a loser quite often, actually.)
Welcome to the fray.
terminator
07-27-2015 07:13 PM
keithporter83
07-24-2015 07:37 AM
whereAreMyPants
07-22-2015 03:32 AM
kyletbert
07-17-2015 11:39 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: bleeding the power steering system??
