Bear with me here!
Old Jul 3, 2008 | 02:28 PM
Trustyrusty's Avatar
Bear with me here!
I and countless others have beaten this topic to death, so bear with me..
At first I decided I wanted a 2" Toytec lift, and 33's...
Then I realized all the added stress lifting an IFS suspension creates, and realized IFS is stronger in stock form, so I was against altering the geometry and strength of the suspension system. I have decided I want a 3" body lift, because its a very solid modification that gives room for bigger tires, and doesn't create a harsh ride like most 4" run of the mill bracket lifts.. I want the 3" body lift no questions asked, but I want to know if I can run 33x12.5's with one, with out rubbing.. I want to purchase my tires from Treadwright.com, and they have either 31x10.5's, or 33x12.5's I think that if I get the 31's my truck will be fairly underpowered, and I would wan't to regear, and while Im at it I miswell regear to 4.88 and run 33's.. But I wanted to know if the 33x12.5's would rub... Also does anyone know how 31's look with a 3" bodylift? Or a 3" lift of anysort, I think they would look small(ish)
Old Jul 3, 2008 | 02:31 PM
abecedarian's Avatar
here's a pic of mine with a 4" suspension lift on p265/75r16's (approx 31")
personally, I wouldn't go over 2" with a body lift, but that's my opinion.
and as for the harsh ride, my 91 xcab rides much rougher.
Old Jul 3, 2008 | 02:38 PM
Yeah, it doesn't really matter, 2" is the same as a 3"...
Thanks for the picture though, I may go ahead and do 31's with a 3" body, even though I guess they would clear stock..
Old Jul 3, 2008 | 02:49 PM
those wheels and tires were on it before the lift went in and I had no clearance problems even with the running boards- had at least 1/4" clearance
Old Jul 3, 2008 | 02:59 PM
just a 22re's Avatar
yeah im stock with 31x10.5's no problem if your goign to go the 33 way then stay with the 10.5 cause i think the 12 will rub not sure but i think they will at full lock that is
and abe we have the same front bumper mines just condoit lol
Old Jul 3, 2008 | 03:54 PM
Jay351's Avatar
It depends on the backspacing of your wheels. If you stick with stock, chances are you won't rub. If you went with a wider offset wheel (3-4"BS) you will have some rubbing. But nothing some trimming of the pinch weld couldnt fix.
Old Jul 3, 2008 | 04:14 PM
wii_tarded's Avatar
My stock '91 4 runner has 31's on it and no rubbing anywhere. In fact I'm looking at going to 33's with no lift. Then I will worry 'bout rubbing.
Old Jul 3, 2008 | 06:56 PM
hatda02's Avatar
I bought 10 inch rims with factory backspacing and 33x12.5's. I had a two inch body lift and gave it a try. The back was fine, but the fronts rubbed into the inner body seam on both sides...cut into the tires nicely!
I cranked the torsion a bit (a little bouncy now), and added the low profile upper bumpstop...and used a BFH on those seams...problems solved.
I would do it all over again too. I love the look of the 33x12.5's.
I also added add-a-leafs in the back to level out what I did in the front. Those blocks are silly.
Old Jul 3, 2008 | 07:37 PM
Basically all I'm asking here, is what do I have to do to fit 33x12.5's on a 3" BL with no rubbing. Oh, and Jay, whats stock backspacing? Thanks!
Old Jul 3, 2008 | 08:03 PM
SLOWBOOST's Avatar
just go with something, if you have to cut/trim something to clear then happens. Nothing ever got started without taking a chance.
Jay351's Avatar
Stock backspacing IIRC is 4.75"
To fit 33x12.50" (mud tires or all terrains/street tires?):
3" body lift
8-9" wide rim with 4.5" of backspacing
Some minor pounding of the pinch weld/inner fender.
Old Jul 3, 2008 | 08:14 PM
I'll be running re-treaded BFG M/T's Are you sure I won't want a 10" wide rim? Thanks for the Info guys! I will be getting 33x12.5's, and If they rub too bad on the trail, I'll get some BJ spacers and Shackles, and beat the ever loving piss out of the inner fender!
Old Jul 3, 2008 | 08:28 PM
Oh, also do you think 4.75" BS would be ok? http://store.summitracing.com/partde...5&autoview=sku Like these?
Old Jul 4, 2008 | 10:01 PM
im not sure with the back spacing as my truck came with the rims and tires on it
Old Jul 5, 2008 | 09:37 AM
Yopar's Avatar
Those should work fine, as the stock BS is 4.75", or very close.
Old Jul 5, 2008 | 01:12 PM
Jay351's Avatar
If you go with 4.75" backspaced wheels you won't be able to run bj spacers without a wheel spacer. Go with 4.5 so you can still run the spacers if you want.
If you were to run a 10" wide rim your tire would be even wider. You might run into more rubbing issues. BUT a 8" rim will make the tire a tad taller when its all set.
With my rims ( 15x8.5 with 3.5" bs) I had some pretty bad rubbing, I pounded the pinch weld, and I added bj spacers so I could avoid rubbing on the street and mild trail use. I still rub under full flex situations. Almost enough to make me sas the bastard
So in closing:
15x10" rim if you don't mind trimming
4.5" backspaced wheel (so you have the option of running BJ spacers)
Old Jul 5, 2008 | 02:37 PM
bigt's Avatar
i run 32.11.50.15 on stock with no body lift and no rubbing with a 3 inch body lift you could do 33s i think i could do them with some trimming or pinching stock
Old Jul 5, 2008 | 07:43 PM
I can either get 4.5" BS wheels that are 7" wide, or 4.75" BS wheels that are 8" wide, that sucks... Which should I get?
ladybugRC
458
Aug 21, 2020 10:41 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Chicken12
Oct 14, 2015 03:54 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
