Battery sits too low
Old 08-13-2012, 04:30 PM
Tomg303's Avatar
Recently I've been having problems with my battery sliding around and disconnecting the fusible link that leads from the battery to the fuse box. My battery can't touch the mount because it sits too low. Is there some spacers that gop below the battery. Mine just goes battery then tray. Can't figure this out. Also what size is the fusible link mine is pretty beat up.
Old 08-13-2012, 04:51 PM
Hilux4Life's Avatar
For my optima red top I have to use the spacer that comes with it. If I were you I would go to your local parts store and see if they have an extra one. Not all trucks need a spare so I am sure it's a dime a dozen for them. They would just give it to you for free.
Old 08-13-2012, 04:53 PM
myyota's Avatar
It sounds like the battery in your truck isn`t the right one.
Old 08-13-2012, 05:11 PM
scope103's Avatar
If your battery is the correct size, sometime in the murky past you might have had some front-end sheet metal damage, so that the apron (the sheet metal between the engine compartment and the wheel well, which includes where the tray sits) is bent.
I use some 1/8" plywood ("paneling") as shims under the hold-down.
Tomg303's Avatar
Its a parts plus 65 series. Son't know anything about the brand. Was put in by PO. I'll call some stores see if they can't get me some height adjusters.
Old 08-13-2012, 07:03 PM
abecedarian's Avatar
Or maybe just get some straps?
Old 08-13-2012, 07:09 PM
ksti's Avatar
I think a pic is in order.
Old 08-15-2012, 05:32 AM
annoyingrob's Avatar
I just stick a piece of wood between the battery and the top mount if this happens.
A ratchet strap also works well.
Old 08-15-2012, 05:50 AM
Marc's Avatar
Me too. I just use a thin piece of wood to make up the height.
Old 08-15-2012, 07:12 AM
Discombobulated's Avatar
Or if your battery is old and nasty might just get the correct one and not rig it to fit. But if it is new rig it till the next time just try not to make it permanent.
kazuya2416
04-05-2024 02:17 AM
icentropy
09-16-2020 02:47 PM
Sleaker
08-26-2020 06:03 AM
jasonty
41
12-23-2018 01:00 PM
luckypig44
07-19-2015 11:25 AM
Quick Reply: Battery sits too low
