| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Ball Joint spacers.
__________________
1995 xcab with blown up 3.0, soon to be 3.9 Cummins.Plans for SAS as well. 1989 4Runner daily driver, 3.0, 3.5 body lift, 35" MTR's. 10-20=Can,NB,SJ. pics: http://www.flickr.com/photos/7439309@N02/ |
#2 (permalink) |
I dont think so, i believe the reason they only make the uper ones is bc the point of the bj spacer is to gain suspension down travel
__________________
89 4x4 4runner; 3.0 5psd topless 2 seater on 33x13.5 LTBs on black 15x10 procomp series 51, aisin manual hubs, custom snorkel, 3" BL , 1.5" SL 04 4x2 xterra 3.5" daystar lift, .5" ball joint spacers, SAW Tbars, bilstien HD shocks, hoohaa steering, idler arm brace, 1.5"wheel spacers |
#3 (permalink) |
I think it's just easier to do it on the top - all you're really doing is spreading the outside end of the control arms apart, so it doesn't matter if the spacer is on the top or bottom...
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#4 (permalink) |
There's a web site www.tkoffroad.com that has a drawing of a spacer. All you need is a ball joint and use that as a template. Thats what I did.
__________________
2007 FJ Cruiser 4x4 285/70-17 MTR's, Home made level lift, Home made Rock sliders, home made lower control arm skides, Home made Highlift jack clamps, AP LCA's, 4 KC's on roof rack, 1987 4runner SR5 22RE 5spd. Budbuilt skids and transf. case cross member, Flowmaster, 32x11.50/15's BFG MT's, Amer. racing rims, home made 1" body lift, winch & brush Guard, Downey truss, 26mm t-bars, home made 1" BJ spacers, Home Rocksliders, home rear quater sliders, Aussie locker in rear 4.30 gears |
#5 (permalink) |
The spacer goes on the upper arm since that is where the torsion bar connects.
- http://www.4crawler.com/4x4/ForSale/...ml#Description If you put a spacer on the lower ball joint, all you would do is spread the control arms farther apart with no benefit.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 05-31-2007 at 08:48 AM. |
#6 (permalink) | |
Quote:
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Total Chaos Uniball Kit, Downey Torsions, Fox 2.0 8'' Reservoir Shocks, Hannemann Fiberglass Fenders |
#7 (permalink) |
Putting a spacer on the bottom would do nothing but drop your control arm closer to the ground.
The spacer goes under the top because thats the only way for it to "lift" the front end up.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#8 (permalink) |
Putting on the bottom mite lower the front, by pushing the spindle up?
__________________
#9 (permalink) |
Perhaps on a 2wd, but on a 4wd it would do nothing.
__________________
#10 (permalink) |
I'm pretty sure the 2WDs have the torsion bar attached to the upper a-arm as well.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#11 (permalink) |
Staff
#12 (permalink) |
then someone put my truck together wrong....
![]() EDIT: yeah i know its dirty but i went through the desert a few times last week and havent hosed it off yet.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd Front: Total Chaos Uniball Kit, Downey Torsions, Fox 2.0 8'' Reservoir Shocks, Hannemann Fiberglass Fenders Last edited by Robert m; 06-01-2007 at 05:23 AM. |
#13 (permalink) | |
Quote:
time to get durty!! woo
__________________
Dead '94 2.4L 22re 2wd pu, k&n air filter, thrush glasspack, 4in over stock rear shackles, 1.5in ball joint spacers, 4in infinity reference dash speakers, pioneer head unit, 10in p2 sub, alpine amp. bed cap topper thingy. great for campin. Current-2004 toyota tacoma, 2wd, 3.4L, prerunner, e-locker, tow package, trd package, ext cab, alpine head unit, polk speakers all around, punch p2 10" run off a alpine mono amp, silver paint. ohhhh its purty... |
| Tags |
| 15, 94, ball, joint, plans, spacers, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ball joint spacers? | 8yota9 | 86-95 Trucks & 4Runners | 24 | 01-24-2007 06:43 AM |
| ball joint spacers | tickt9842 | 93-98 T100s | 13 | 03-19-2006 08:41 PM |
| Ball joint spacers??? | 4unner4life | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-02-2005 02:11 PM |
| Ball joint spacers. | az4x4runner | Offroad Tech | 15 | 01-14-2005 07:56 PM |
