aweful noise sounds like from tranny i dont know
Old 08-02-2010, 05:59 AM
mushukilla's Avatar
Aweful noise when Clutch is Disengaged I just bought a my 89' about a month ago its my first t4r and my first 4x4. I had no sound at al from it all the way home and I even moved it around alot the first month without an issue. The noise happened after me feeling my way through the gears with the truck off. I was also going through the 4wd selector. my dad got in after that and i remember him pushing the Clutch start cancel button after two tries Clutch start cancel button after two tries because the battery was too low to start it. Then it started, and then making this aweful scraping noise. it kind of sounded like pigs squealing but more scraping than anything. It only happens when the clutch is Disengaged though. off the clutch and the noise stops, back on and its bad sounding. any suggestions. My dad said it sounded like it was just something that needed some adjustment.
Old 08-02-2010, 06:07 AM
xxxtreme22r's Avatar
throwout bearing maybe? how old is the clutch?
Old 08-02-2010, 06:16 AM
mushukilla's Avatar
The Clutch isn't that old at all and the truck was silent days before would the bearing just happen that sudden?? Wouldn't there be some warning at all??
Old 08-02-2010, 08:09 AM
RBX
RBX's Avatar
Yes a cheap throughout bearing will/can just go up. I had a 92 and put a cheap clucth kit in it, the bearing was destroyed and made a horrible noise. You may be able to peak at the bearing through the clutch fork boot on the side of the tranny.
Old 08-02-2010, 09:53 AM
Flash319's Avatar
Are you sure your transfer case is in a gear?
Old 08-02-2010, 05:15 PM
mushukilla's Avatar
shouldnt the T-case just stay in neutral? I was goofing around with it while the car was off shortly before starting the truck and getting the noise but im pretty sure the t-case was in nuetral the whole way i drove it home. Does it have to be in like 2w-h or something? maybe i just goofed it out of gear?
Old 08-02-2010, 05:51 PM
Flash319's Avatar
2H. The trans drives through the transfer case.
Old 08-02-2010, 06:03 PM
mushukilla's Avatar
well if it wasn't in gear then I wouldn't be able to move it would I? It goes just an vaweful sound when clutch is disengaged.
Old 08-03-2010, 03:51 PM
pruney81's Avatar
Noise when the clutch is disengaged (pressed in) could be the throwout bearing. I know when I did mine I went with an OEM AISIN clutch kit. I'd start there.
JNapolitano
11-14-2019 07:46 PM
norcal98
08-10-2015 06:20 AM
yourrealdad
07-21-2015 11:13 AM
mlavery85
07-12-2015 10:33 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: aweful noise sounds like from tranny i dont know
