Anyone reuse thier clutch?
Old 02-08-2007, 11:26 AM
mtrdrms's Avatar
I am wondering if I should reuse my clutch or change it while I have the engine out. It looks to have alot of life left to it and I always like the stock clutch over aftermarket on these trucks. Also which way does the clutch plate face?
Old 02-08-2007, 11:29 AM
bob200587's Avatar
I'd do it if it hasn't been done before. Or you don't know who used the truck before you.
Old 02-08-2007, 11:55 AM
surf4runner's Avatar
do it now.
new
when are you gonna have it apart again?
Old 02-08-2007, 08:43 PM
notanymore's Avatar
look at it this way, would you rather spend the money now or 6 months down the road deal with it again, its just alot less labor, personally i would replace it, i am when i put my engine back in
Old 02-08-2007, 08:50 PM
Numbchux's Avatar
it's hard to say. if it's got a bunch of life left on it, I'd re-use it. I've re-used a couple clutches on my old subarus...
IMHO, clutches are expensive....I'd rather do some extra work to get my $$s worth out of the one I have. but it's up to you. if you want to prolong the job as long as possible, buy a new one and replace it now....
Old 02-08-2007, 09:38 PM
Elton's Avatar
how many miles are on it now ?
Old 02-08-2007, 09:51 PM
Staff
DeathCougar's Avatar
Its kinda like the head bolts situation.
yea, you could reuse it BUT...whats the Peace of Mind worth to you?
Old 02-09-2007, 04:09 AM
mtrdrms's Avatar
Good responses so thanks guys. There is alot of life left on it and I really dont have the money so I think I am gonna reuse it.
Old 02-09-2007, 04:30 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Just make sure the bearings are real good.
Old 02-09-2007, 04:48 AM
mtrdrms's Avatar
The pilot bearing? Its new.
Old 02-09-2007, 10:01 AM
maxpower_hd's Avatar
I re-used mine too. However it did only have a couple thousand miles on it too. The guy that owned it before me put a new clutch in it and then a few months down the road, the motor spun a bearing.
But if it's got a bunch of miles on it then I'd go ahead and replace it. You will kick yourself if you're lying under there in 6 mos doing the clutch when you could have done it sittin on a stool.
Old 02-09-2007, 01:58 PM
Numbchux's Avatar
Throwout too...one of those subarus that I re-used the clutch on, the throwout bearing was pretty worn. so whenever the clutch was engaged (no pressure on the bearing) it would squeek....REALLY irritating!!!
Old 02-09-2007, 03:39 PM
rhah's Avatar
If everything is within spec why replace it?
Old 02-09-2007, 03:47 PM
titicaca's Avatar
i bought a lifetime warrantied clutch if i pull the tranny it goes back.... also having your flywheel resurfaced with a new clutch will help it last longer and will help cut down on that annoying chatter.
Old 02-09-2007, 03:52 PM
Robrt32's Avatar
Anytime i have ever had a motor or transmission out , I replace the clutch.. I don't know about you but i don't really enjoy laying under 1 with grit and dirt falling in my eyes
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Anyone reuse thier clutch?
