| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
AFM air flow meter flap not operating correctly???
__________________
Kevin 1990 Toyota DLX, rebuilt 3.0, manual, centerforce clutch, 3 inch BL, 4.56 gears, Firestone Destination M/T 33x12.50, Pacesetter exhaust, Taurus fan mod 1996 Dodge 2500, Cummins Diesel, 5 speed manual custom exhaust 1961 Chevrolet Impala- Just started off frame restoration. 1994 Jeep Grand Cherokee 4.0, Auto, stock |
#2 (permalink) |
Did some more checking and with the AFM door manually opened and OHM readings were correct. Does anyone know if this is this correct: AFM door closed Fc - E1 circuit OPEN, AFM door open Fc - E1 circuit closed with no resistance? The Haynes manual does not specify
__________________
#3 (permalink) |
I don't have the service manual handy to check what it should be. But I can tell you that there's a good chance the flapper door is simply dirty from corrosion.
You can check for this very easily by moving the vane with you fingers and feeling its motion. It should move smoothly with no sticky spots or grindy feeling. If it's not moving freely, don't panic. They can be repaired. I repaired mine and it's working like new. |
#4 (permalink) | |
Quote:
#5 (permalink) | |
Quote:
__________________
#6 (permalink) |
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Air Flow Meter | MAXIMUS1968 | 86-95 Trucks & 4Runners | 5 | 09-30-2006 08:38 AM |
| Air Flow meter | GVOLCRunner | 86-95 Trucks & 4Runners | 0 | 09-24-2006 01:10 PM |
| air flow meter | toymini82 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-30-2004 02:03 PM |
| Air Flow Meter HELP!!!! | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 09-23-2003 01:22 PM |
