AC Push Button Switch Changable?
Old Jul 3, 2008 | 02:18 PM
Hyperwrx's Avatar
My plastic switch internals broke. I tried super gluing it and it appears to be unrepairable. I am hunting for a new one but they're apparently hard to find.
Can I install a typical flip switch to accomplish the same thing the stock switch did? Anyone else ever done this? Maybe a a 3rd party push button switch? The harness is a 3 wire harness and I know the switch is lit up when depressed so one of the wires is for the light and the other two for the switch itself?
I'm not much on 12 volt electric stuff. Someone able to help?
Thanks
Old Jul 3, 2008 | 03:30 PM
just a 22re's Avatar
yes very easy i can try to make you a picture of what to do hang on my paint has gotten much better!!!!
all you do is fuse the 12 volt power from the battery
12v switched goes to the a/c
ground well you should know this one it goes to the frame or metal to make it light up
Old Jul 3, 2008 | 03:44 PM
Hyperwrx's Avatar
Thanks.. easy as pie.
Old Jul 3, 2008 | 04:05 PM
RobD's Avatar
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
eBay is where I picked mine up.
Old Jul 3, 2008 | 04:08 PM
check to make sure that thats the way they are cause the ground might be in the middle so look at the switch before you do it lol
Old Jul 3, 2008 | 05:04 PM
InternetRoadkill's Avatar
I got one sitting on my desk.
Old Jul 3, 2008 | 05:11 PM
Hyperwrx's Avatar
Originally Posted by RobD
Wrong year.
In the end I think I'll just make one myself. Simpler and my compressor isn't hooked up to the wire harness anyhow so I'd be either running a new wire or taping into the harness.
Thanks for the help guys.
Old Jul 3, 2008 | 08:17 PM
RobD's Avatar
That the one?
Old Jul 3, 2008 | 08:22 PM
Hyperwrx's Avatar
Heater /ac fan control switch is what that is so no.
There is a button that lights up green wheny ou push it that turns on the AC in a toyota truck.
Old Jul 3, 2008 | 08:27 PM
well i hope i helped you out a li lbuddy
jasonty
41
Dec 23, 2018 01:00 PM
ManzDaKlown24
Aug 22, 2015 10:25 PM
JHalcyonM
Aug 4, 2015 01:19 PM
RustBucket
Jul 24, 2015 04:46 AM
icentropy
Jul 14, 2015 10:23 AM
