ac not working
Old 08-07-2008, 01:50 PM
fireman1559's Avatar
ac not working
my AC will not work when i push the AC button the light comes on but nothing happens the compressor never kicks on i do have a AC compressor i have all the hardware
what should i do?what is wrong?how can i fix it?
Old 08-07-2008, 01:54 PM
InternetRoadkill's Avatar
It's low on gas more than likely.
Old 08-07-2008, 02:10 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I just went thru this same thing on an exploder.The light for the AC came on when you pushed the button, but nothing. The blower motor was bad, replaced the motor, and the AC worked, defroster, everything worked. Check your blower motor
Old 08-07-2008, 02:47 PM
it works
Old 08-07-2008, 04:09 PM
toddowaddo's Avatar
Jumper the low pressure switch momentarily to see if the compressor kicks in. If it does you need to add refrigerant. Then you'll you'll probably have to find a leak.
Old 08-07-2008, 07:46 PM
how do i jump the low pressure switch
Old 08-08-2008, 10:02 AM
toddowaddo's Avatar
Not sure if you have the same dual pressure switch that's on my '94 or just a plain old low pressure switch. Either way, you're going to have to go behind the glovebox to find out. Check out this site, it will show you how to test everything properly.
http://personal.utulsa.edu/~nathan-b...ditioning.html
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: ac not working
