94 3.0 won't start
Old 09-23-2006, 02:07 PM
misterzee's Avatar
94 3.0 won't start
So, I acquired this 94 4runner. When you hit the starter, it stumbles once, then no more. I loosened the bolt on the cold start injector, it squirts, so I'm thinking there's fuel pressure. Ingition timing is cold-set to the center. Under-the-hood condition looks real good, no sloppy workmanship on previous work.
I did observe two vacuum tits that have no hose on them. Experts have some imput for me?
Old 09-23-2006, 07:48 PM
MRunner's Avatar
Those 2 are normal, the one on the inner fender is is fine the way it is, just make sure the one on the throttle body is thoroughly plugged.
So every time you try to start the engine, it cranks fine and fires for a second like its almost going to start?
Old 09-24-2006, 04:07 AM
misterzee's Avatar
The first time i turn the key, it'll spin, stumble for a few revs, and then only spin, no attempted firing.
Old 09-24-2006, 04:37 AM
TNRabbit's Avatar
Check the basics: fuel, air, spark. My next guess would be a VAFM problem or hole in the intake hose.
Do you have any history on the vehicle?
Old 09-24-2006, 11:50 AM
misterzee's Avatar
The only history I have is the previous owner drove it for a year, and then blew a HG. It was a self-repair, done in a shop owned by some friends who do custom cars. They seemed to have all the necessary tools, facilities, smarts to do it right. He said it drove fine after they re-did the HGs, and he parked it. After sitting a month, he went to move it and it would not start. He had already decided to sell it. So I bought it and towed it off.
Here is a wire that seems to be looking for a socket, which I cannot find, its on the passenger's side of the engine compartment. Also, I pulled a plug, its new and wet with gas, and there's a pretty good looking spark.
Any help here is appreciated.
Old 09-25-2006, 03:12 AM
TNRabbit's Avatar
I'll look at mine when I get home today & let you know.
Old 09-25-2006, 07:04 AM
miket223's Avatar
That wire hanging over your diagnosis port in that picture is your compressor clutch connector. Find the other end of that wire which will be coming out of the main harness and plug it in if you want your A/C to have a chance at working. Good luck on getting your truck running though.
Old 09-25-2006, 08:27 AM
misterzee's Avatar
Thanks! So once we get it running, we'll be cool.
Old 09-25-2006, 01:57 PM
SpeedyJ's Avatar
It could be flooded from trying to crank it. Take the plugs out and let them dry and crank the engine to push out excess gas.
Old 09-25-2006, 07:42 PM
bobben's Avatar
Having sat for a month and not run the injectors probably are plugged up especially if the gas went bad. Or had water in it. The cold start injector is harder to plug up.as it is larger. I am assuming the spark and ignition has been checked out.
Old 09-25-2006, 08:02 PM
Bumpin' Yota's Avatar
ooooh good point!!
Drain the gas tank, put good fuel in and see what happens.
Also check the engine's timing...
Old 09-26-2006, 02:58 AM
misterzee's Avatar
OK, I'll try that, it just did not occurr to me that an EFI system could be 'flooded'. Never seen it happen.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Yota.Jay
07-23-2015 08:08 PM
MTLroadierunner
07-15-2015 12:58 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 94 3.0 won't start
