| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
90 4Runner Starting Problems(Update)
#2 (permalink) |
get yourself a haynes manual, read the section about re & re the starter. check all your grounds and clean them up, do the positives while you are at it. use the search feature at the top of each forum page and type in 'starter contacts' or 'replacing starter contacts' or similar. you can decide what to do about the dealer problem once you figure out what is wrong.
another option is: www.4crawler.com , look for starter contact repair in his write-ups. lee
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#3 (permalink) |
Description of Work Done
Starter Solenoid Recon $148
R+R Starter 66 G/R Starter Motor Pole Piece(2) 45 Total: $259 |
#4 (permalink) |
my '84 did kinda the same thing. turned out to be the ground wire on the battery. when i went to check the battery and cables, the ground wire pulled right out of end. it just depended how the wire was wiggled wether it would start or not. the lights would work and everything, the wire just didn't have enough contact to run the starter.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problems Starting My 87 4runner | darylb13 | 86-95 Trucks & 4Runners | 9 | 04-12-2007 09:22 AM |
| 4runner stalling and starting problems | ff11979 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 05-15-2006 05:40 AM |
| Problems starting my 4runner | 90 4Rnner | 86-95 Trucks & 4Runners | 5 | 03-18-2006 12:13 AM |
| 87 4runner starting problems | gerbir | 86-95 Trucks & 4Runners | 1 | 02-13-2006 07:28 PM |
| 90 4runner not starting | outdoorfever | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-03-2005 09:33 PM |
