89 4Runner gas sender in a 86?
Old 01-30-2016, 04:50 PM
GeoRoss's Avatar
I found a pristine gas tank, pump and sender today in a salvage yard. i didn't get it today because I wasn't sure it would fit in my 86.
My internet searching Kung Fu has failed me. Will these cross over?
Old 01-30-2016, 11:06 PM
Staff
Terrys87's Avatar
It will work. I cant remember which plug is different on the float or fuel pump assembly that is different but I have just wired in the correct plug in the past and it works. One is a round plug and that is the one that is going to be different. The other will be a flat plug. The wiring is the same color so I just switched plugs by soldering and shrink wrapping.
You said 89 runner to 86, in your signature I am assuming you mean an 86 Runner as well. If it is an 89 runner to 86 pickup, no then they wont interchange. Pickup and Runner tanks are different.
Old 01-31-2016, 05:08 AM
GeoRoss's Avatar
Thanks, that is correct an 89 4Runner tank, sender, pump, float going into an 86 4Runner..
Thanks again.
kawazx636
03-23-2023 09:37 AM
toyturtle
01-27-2016 12:00 AM
91mudrunner
01-10-2016 12:36 PM
MudHippy
01-02-2016 04:52 PM
Quick Reply: 89 4Runner gas sender in a 86?
