'89 3.0 TPS part number problems
Old 08-03-2007, 10:09 AM
VAfish's Avatar
So, I've been searching & can't find the answer. I have a 1989 3.0 4runner giving me a "can't read TPS" code. So I go to the junk yard & am in luck, a '93 3.0 with the throttle body still attached so I pull the TPS.... they'll be the same, right? 3.0 <-> 3.0... get ready to switch & I see different part numbers??? I now know there was a P/N change but just need assurance that if I adjust it correctly the new one will work. Anyone else done this?
Original P/N - 89452-28030
"New" P/N - 89452-12040
Old 08-03-2007, 07:27 PM
Staff
DeathCougar's Avatar
the 93 will not work on the 89. Different part numbers means different parts.
Old 08-03-2007, 07:28 PM
Staff
besides Toyota changed a number of things in 92, including water passages, and timing belt tensioner. They also changed many things in wiring, etc etc. Toyotas wiring harnesses only interchange in an about 6 month period.
Old 08-03-2007, 08:01 PM
JackKnife's Avatar
You can use the newer TPS if you change two other parts. First, you need to change the plug. The newer one has a rounded plug while the older one is squared. Secondly, (I don't know what one would call this part) you must change the metal part on the throttle body that actually moves the TPS. The reason this needs to be changed is that the newer TPS internals are clocked 90 degrees differently than the old one.
Old 08-03-2007, 08:02 PM
4Crawler's Avatar
You can test the TPS you have, it may just be out of adjustment:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Or it could be a wiring issue between the TPS and ECU.
Old 08-04-2007, 07:36 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Some of the TPS sensors and connectors had a different number of terminals, also. I've seen that before....not sure what years, though.
You can test the terminals at the ECU end of the TPS for continuity. It's really very simple.....if you have an ohm meter, I suppose. Look under "testing the ECM wiring resistance" (EG2-256)in the FSM.
http://personal.utulsa.edu/~nathan-b...e/102engin.pdf
And just a tip, it'd be so much easier on you if you used a TPS for your year model.
94 Newbie
07-06-2015 04:23 AM
bprice0077
06-25-2015 07:36 AM
Chooch
06-19-2015 03:05 PM
TheManOutside
06-18-2015 03:32 PM
ShaunKris
06-17-2015 04:33 PM
Quick Reply: '89 3.0 TPS part number problems
