| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
'88 4runner - 22re cooling system disaster - PIC request please!
#2 (permalink) |
Mine sits like 2 inches above the core support, my friend who has a body lift (3") has his sitting an inch below the core support, its way down there.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag... Blown head gasket 12-06-2009, 212k miles Re-assembled and running 2-2-2010 |
#3 (permalink) |
when i installed my new radiator(spectra) with a larger cap it also had clearance issues (no pics, i'm rebuilding the engine, sorry)......but i mocked-up a cap with foil and dropped the hood to see where it hit. turned out i had to make some relief cuts (two approx 1/8'') in the hood bracing where it hit and then it was fine.
__________________
1992 4x4 shortbed /22re/auto/192,000 miles--original owner(rebuild in process) 1988 SR5 4runner /V6/5 speed/248,000 miles/bought April 2009/***UNDER CONSTRUCTION*** 2006 SR5 4runner (the wife's)....still being paid for... >>>>***Check out My SLOOOOOOW Re-build Thread***<<<< http://www.yotatech.com/f116/92-toy-...-start-188472/ |
#4 (permalink) | |
Quote:
-Chris |
#5 (permalink) |
Why not just get the correct radiator to solve the problem ???.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#6 (permalink) |
I've been trying, but apparently I, just like the mechanics at the local Toyota service center, as well the podunk mechanics at the shop in Indiana where it broke down last week, "couldn't get one." I found out yesterday after opening a complaint with the dealer, that they got there from Weaver auto parts, and the Indiana shop got theirs from Carquest. I would love to have a OEM radiator, but apparently, they are harder to find than the culprit behind my fuel supply/ignition problems.
The Toyota dealer put one in this february when I had numerous oil seal failures and had most of the coolant system replaced as well. The indiana shop put one in last week when the "toyota" one developed a fracture at the base of the filler neck, likely in part from the pressure of the hood pressing on it. |
#7 (permalink) |
The hoods are probably different but here's what I did.....
![]() ![]() to acomodate a higher radiator with a larger cap ![]() However. on my son's '88 3vze we replace his radiator with the same brand(Spectra) and had no issue, but it's a different engine
__________________
#8 (permalink) |
Go to radiatorbarn.com and you can get an oem replacement that will fit like the original radiator, i bought a three core replacement radiator from them for my 86 4Runner and its working good.
__________________
| Tags |
| 22re, 4runner, 92, coolant, cooling, core, downey, parts, pic, radiator, sr5, system, toyota |
