86 Runner Light Wiring
I have been thinking about getting both fog lights and driving lights for my 4Runner. I want to make it so that the driving lights only come on with the high beams and I want the fog lights to come on with the "dome light" switch (I have a completely different interior lighting situation). Does anyone know how any of this can be done?
You sure you wanna control it with Dome Light switch? Then, you'd have to run a control wire (low current, 18AWG) from your dome light (overhead) down to your fog lights relay. This will have +12V so this will energize our fog lights relay. Relay is best placed inside engine compartment and physically between battery and lights to minimize length of high-current (load=lights) wires.
Driving Lights Only With High Beam
Find wire that gets +12V when you switch high-beam on. Tap to this wire and send to positive of your relay coil.
Connect negative side of relay coil to wire and run wire to switch on dash. Connect other side of switch to ground point on A-pillar.
Connect the rest the way you would wire fog/driving lamps.
Regards,
RAD
I feel dumb, DECK light switch. I already have a plan in motion that will make the deck light useless, so using the switch for fog lights would be nice.
For the driving lights, can I just run a straight ground instead of having a switch in the dash so that the driving lights always came on with the high beams?
Tapping the + of the relay to the taillight circuit would allow the fog lights to come on with the running lights, like the deck light already is setup?
not sure why it wouldn't, but ill take your word
I feel like I am asking a lot of dumb questions, thank you for just rolling with it!
If you could wait, let us figure out exactly how the re-used Deck lamp switch should be wired.
Asking questions is not dumb. Just connecting wires anywhere without making sure is. LOL!
Regards,
RAD
According to the wiring diagram I'm looking at right now your left headlight has a red/white high beam wire and your right head light has a red/black high beam wire. You can also catch a high beam signal behind the instrument cluster going to the high beam indicator which is red/green. Be sure to use a relay.
Your second question. Yes you can but it may not be legal in all 50 states. You will still need to use a relay.
