86 4runner - parts list for lift - anything else to add?
Unless I find a really good deal, I think I'll be sticking to a non reservoir shock for now. The eventual plan is a Total Chaos LT kit, so I want to keep the expenses in check until then.
Any other suggestions while we have this post rolling?
I definitely wouldn't bother buying new wheels with the stock backspacing, a bit of cash to spend when you will eventually want a wider wheel (especially if you go TC and lose a few fitment issues with larger tires).
Just for kicks. Would this shock fit?
FOX 980-99-021-A 5.0 EMULSION
http://www.camburg.com/fox.html
-jeff
-jeff
-jeff
-jeff
I worry primarily about the front shocks, I don't seem to have as much problem with rear shock fade or I don't notice it, one of the two.
You might just find a good pair of front shocks and give them a try. Already with the spacers you are using a longer shock with typically a larger diameter shock body holding more oil and valved more aggressively than the stock. That will yield a pretty big improvement right there.
Frank
#26
You should talk to TC then and get shocks that will fit their setup, I would think they would fit stock, might need a hoop. Would seriously spread out the spend then, as the shocks are an expensive part of the lontravel setup...
#28
Before I here back from Total Chaos I want check to see if the shocks I have right now will fit with a BJ spacer, here are the specs:
Ironman suspension Nitro shock
#12088GR
http://www.ironmansuspension.com/specsnitrogas.html
collapsed: 9.64 inches
Extended: 14.49 inches
Will these be close enough to fit?
Merry Christmas,
Jeff
#12088GR
Merry Christmas,
Jeff
#29
You might *just* make it. The 14" shocks are too short and at 14.49 you are riding the line. 15" shocks make it so sweat. It's no biggie though, you can just shim the shock a little bit.
Frank
Frank
#30
Thanks Frank. I'll be giving you a call to put in my order & chat about shimming those shocks. Drop me a line when you get back to work from the holidays.
cheers,
jeff
cheers,
jeff
#31
Just ordered some BFG AT 32x11.5s to go on the truck this spring. Hoping all goes well. The final setup will be as follows:
-15x9 rims with 4.5" backspacing (gonna give them a try at least)
-2 1/2" rear springs (ironman) with greasable shackles
-1 1/2" BJ spacers up front
-Sonoran Steel IFS brace
-OME steering stabalizer
-Ironman shocks on all 4 corners
-Low profile bumpstops
-All new Energy Suspension bushings for the front & rear including sway bar bushings
-Grant 1064 Formula Steering wheel
-New upper & lower ball joints
Any comments? Tips?
I'll post before & after pics when done.
cheers,
frozen
Any comments? Tips?
cheers,
frozen
duckhead
07-17-2015 04:45 AM
TheManOutside
06-18-2015 03:32 PM
