86 22rte missing
86 22rte missing
OK. i bought an 86 22 ret a couple months ago. The guy i bought it from said it wouldnt pass smog so he said he changed one spark plug that looked bad ( ill get to that in a minute) and did the valves and timing. I bought the truck and went to the smog shop and passed smog.
The tech said it was a good looking truck but it had a small miss around 2500 rpm. I noticed an idle miss and a miss around 2500 too.
I then replaced all plugs and wires and the tps and adjusted it according to 4crawl website.
the miss is still present and i am stumped. i know my turbo is cracked on my exhaust housing could that be the culprit? Im gonna have it shpped out to turbo electric to be serviced.
I pulled the spark plugs today and i found that #4 plug looks like Sh**. I cant understand it. it doesnt smell like gas and it was a little oily so i checked compression on the #4 cylinder again and its @ 150.
Could it be my injector? Cap and rotor? I double checked my tps and its within spec on all 4 tests. IM STUMPED AND NEED HELP
The pic with 2 plugs is #2 and 3. The other clean plug is #1 and the nasty one is #4. plugs are two months old
Valve seals, stuck ring, crack, gasket
If its def oil there are only so many options.
What are the chances it's a head gasket or crack?
Is it moded out, or still stock.
Pics help.
Pics help.
My rte was the same, really oily plug in #4 cyl. Sounds like valve seals, another thing to check is your egr stuff. Mine was completely choked with carbon. Hope this bit helps!
But also, oil in a cylinder will raise the compression when you check it
Sam hain
19
09-30-2015 08:25 AM
