86 22re rebuild dilemma
Old 09-29-2009, 05:55 PM
valaken's Avatar
i recently pruchased a pickup,86,from a guy i know. it was just collecting dust in his garage,he started to tear down the motor himself for a rebuild but never finished. i bought it in hopes of finishing it and having a nice yota for myself on the weekends (89 yota pickup daily driver) only one big problem,he didnt label anything. bolts and hoses and all the little things are just in a pan,intake and exhaust manifold are removed,wiring harness is all unhooked. i have no idea where to begin. would it be easier to try and rebuild this or purchase a new motor all together? this would be my first rebuild mind you,so any info would be greatly appreciated.
Old 09-29-2009, 06:11 PM
olharleyman's Avatar
Well first off take pics of the bolts and post them that would be the easiest way to help you figure out what go's where, this way someone can copy your picture and use paint or something to label them and re-post so you can look at them and see what is what.
Old 09-29-2009, 06:13 PM
jsn_stockard's Avatar
I would still do the rebuild. Hoses are easy, diagrams of routing are on here in several threads. When going back together, just take your time and don't force a bolt if it stops. Check depth on water pump bolts before going together, the length matters. Maybe there is a member of YT in your area that can give you a hand, where are you from?
Old 09-29-2009, 06:34 PM
pntbol11's Avatar
Rebuild that thing man! It can be done. Everything you need is on here. I would buy a haynes manual or download a FSM though. Read every build thread you find! I recommend superbleeders personally.
Old 09-29-2009, 08:18 PM
wabtfin's Avatar
I would definately download the FSM from the link on this site. It saved my life. You might also try to sweet talk someone from a Toyota Dealer Parts Department into printing out some diagrams for you. A couple close to me have done so for me and it helped me find out what a cold start injector banjo bolt looked like! Stay in it.
Old 09-29-2009, 08:31 PM
dark_fairytales's Avatar
x2 i agree. if you can post some pics i know we could all help you out by identifying things. Do check out superbleeders rebuild it is vary detailed. I personally know the 22er well so it should be easier than it look. believe me when I say the 22er really only look scarier than it is.
Old 09-29-2009, 08:44 PM
If you check out my 22re rebuild you may be very interested in finding out that I did my build with only info I gathered from this site and it's user's and this is my very first time ever doing this kind of job.
https://www.yotatech.com/forums/f116...begins-185041/
Old 09-30-2009, 02:37 AM
92 TOY's Avatar
i'm in the middle of a tear-down of mine.
i've been using BOTH of the recent threads by IAMSUPERBLEEDER and OLHARLEYMAN and have my own going on as well (see below in GREEN)
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
coleypull15
11-03-2015 07:41 AM
shisha1999
09-21-2015 08:22 PM
shadowbirdie
07-21-2015 10:38 PM
Quick Reply: 86 22re rebuild dilemma
