85 22r SA needs new head gasket. A little help?
Old Mar 29, 2009 | 08:47 AM
toyospearo's Avatar
Hi, my Friend needs to have the head gasket replaced on his 85. I figure its a good rig to do my first one.
The rig is an 85 22r carbed, solid axle. Before I start pouring over the FSM I thought it would be helpful for me to get a quick idea (in order) of what needs to come off prior to the head.
Any list in order would be very helpful to me.
I will document the job and do a write up here on YT
Old Mar 29, 2009 | 06:44 PM
toyospearo's Avatar
wow, no one wants to show their mettle??
Old Mar 29, 2009 | 06:51 PM
86Toyrunna's Avatar
sorry toyo.. havent had to do a hd gasket or a timing chain (been lucky so far) but i have done watter pumps, oil pumps and the other extierior accesories. when i did my oil and watter pump on my 85 i eneded up just pulling the radiator, it made it really easy to get to the front of the motor... well thats about all the help i can be..have fun
Old Mar 29, 2009 | 06:53 PM
TOYOTA 1's Avatar
well being that its carbed that will make things easier.
dizzy.
power steering pump(leave lines attached).
exhaust manifold(should be able to leave it attached to the down pipe and just tie it off to the side).
intake manifold.(leave carb on)
heater hoses.
ground wire (back of head to the firewall).
valve cover.
should also do a timing set since your there.
Old Mar 29, 2009 | 07:07 PM
toyospearo's Avatar
YOU ROCK DUDE!
I appreciate that very much. I am about the dumbest guy I know and a tiny bit of push in the right direction is helpful!
thanks 86toyrunner!
I will post up some pics of this nightmare so you will have a reference someday.
Old Mar 29, 2009 | 07:31 PM
Outsane's Avatar
water pump too
Old Mar 29, 2009 | 07:46 PM
toyospearo's Avatar
WHAT?? the damn water pump has to come off too???
I haven't even cracked the FSM. Good god! This is going to take me a few days.
Old Mar 29, 2009 | 07:47 PM
BLKNBLU's Avatar
Don't spare the tape. (mark/label EVERYTHING)
Don't spare the memory before teardown. (take a million zillion pics while it's still together)
Get your parts from Ted (engnbldr)
I got this kit http://cgi.ebay.com/ebaymotors/TOYOT...1%7C240%3A1318 and it was of fantastic quality. You don't have to have new bolts in the 4 cyl like you do in the 6 cyl but it makes it a whole lot nicer. Or you can get studs as Roger suggests on his site which I will link below.
Helpful links
Tips from Roger Brown
http://www.4crawler.com/4x4/CheapTri...ds/index.shtml
The '93 service manual if you don't already have it.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
An '85 FSM if you've just gotta have one. But it's a PITA to use compared to the '93
http://www.functionalfab.com/resourc...%204runner.pdf
I used the '93 manual for my '86 and it was just fine.
You might as well just print out the whole cyl head section of the '93 manual and take it out in the garage. Then you can just pitch it when your done because it'll be toast by then anyway.
I fudged Rogers stud trick by cutting the heads off of 4 of my better old head bolts and used them to line up the head for replacement, then pulled them and replaced them with the new ones.
Good luck and have fun. I did.
Old Mar 29, 2009 | 07:48 PM
Outsane's Avatar
If you do the timing chain then yes..
the water pump will have to come off...
so you might as well put in a new one.
Old Mar 29, 2009 | 07:50 PM
BLKNBLU's Avatar
Only if you're doing the timing chain too. I didn't on mine as the chain had been done about 50K prior and still looked good.
Old Mar 29, 2009 | 08:14 PM
toyospearo's Avatar
Thanks BLKNBLU!!!
That few minutes you took to cite that stuff will save me tons of time!
At the moment I am sitting here eating a cheese log from Costco, a box of Triscuits, drinking a Coors Light and reading the FSM section on "head gasket removal and replacement."
One of those 4 things is making queezy and I don't think its the cheese log from Costco, the Coors Light or the Triscuits
Old Mar 29, 2009 | 08:41 PM
BLKNBLU's Avatar
More good readin' for your tummy.
Pretty much all EFIs but good pics none the less. Plus mining the links is helpful.
https://www.yotatech.com/forums/f116...nt-pics-88722/
https://www.yotatech.com/forums/f116...earned-101694/
https://www.yotatech.com/forums/f116...s-tips-106376/
https://www.yotatech.com/forums/f115...-build-164835/
Old Mar 29, 2009 | 08:45 PM
BLKNBLU's Avatar
drinking a Coors Light...
Hmmm. I've got a couple Killians in the fridge. I think it's time for a
Old Mar 29, 2009 | 09:05 PM
toyospearo's Avatar
seriously, I would buy the Killians Brewery for you if you came over and helped me with this 85 HG. The Coors Light gives me just enough of a headache to mask the headache from thinking about this 85 head gasket.
Old Mar 29, 2009 | 09:32 PM
camo31_10.50's Avatar
im about to be on my 3rd (yes THIRD) headgasket in just a few months...first time..blew it fo sho!..
second time cam was bad...and it COMPLETELY wore out in just 2500 miles
now the third time...oil pump gave out on me..guess my idiot light dont work...and it ate all the bearings up..hahaha...i figured since i pulled the engine anyway...why not rebuild it..bore it...cam it...all that...so theres where im at..waiting for my block to get back from the machine shop..and waiting on my parts from engnbldr.com
^^^ he is awesome!
take the manifold off, tie it back
do the same with the exhaust manifold
do the same with the A/C and the power steering pump
drain your antifreeze...i think..haha
remove your head bolts...but not your cam bolts..
what else guys????
if you want to give your motor a lil more pep...might as well throw in a new cam...engnbldr 261* for low end grunt...or the 268* for more high eind power...i do more highway driving with 31's than anything..so im going with the 268* cam...unless someone chimes in on the 261* also bein ok for this stuff...
and when you do that.you might as well get a header...then a new exhaust from there back.
its neverending....and i hate it...HAHAHAH!!!
Old Mar 30, 2009 | 08:09 AM
toyospearo's Avatar
I found out this morning the timing chain was done about 50,000 ago. SO, I don't need to do it.
How will this change the order of stuff to come off? What don't I need to take off as a result of leaving the timing chain?
Old Mar 30, 2009 | 08:14 AM
Outsane's Avatar
You can leave the water pump on...
Old Mar 30, 2009 | 08:22 AM
TOYOTA 1's Avatar
yea, the h20 pump can stay on.
every thing i listed still needs removed.
have you started on it yet?
Old Mar 30, 2009 | 08:29 AM
toyospearo's Avatar
I am headed out to do it was we speak. I need to make a trip to Wally World to get a new digi camera. My old faithful Nikon broke.
I will post pics and update the job.
thanks Toyota1
Old Mar 30, 2009 | 08:39 AM
TOYOTA 1's Avatar
hey no problem!
was the nikon just junk, or did you just drop it one to many times?
