3vze cam bearings seizing? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-29-2007, 09:02 PM   #1 (permalink)
I have a dry bearing noise on the top front of the engine... the dry spinning goes in and out. previous to this i had a high pitched bearing noise from the same area after a hard rain and thought i got dust in the cam bearings. does this sound possible or does anyone have any experience with this? would this noise be more likely my timing belt tensioner?
dusktugdawn is offline
Old 07-29-2007, 09:24 PM   #2 (permalink)
Blurr's Avatar
sounds more like one of the timing pulleys. there aren't ball bearings on the cams so it is definitely not that.
any idea when the timing pulleys were last replaced?
__________________
93 4Runner - 3vz-e. bone stock, HG job done in 8/07.
2001 Sequoia SR5
Blurr is offline
Old 07-29-2007, 09:42 PM   #3 (permalink)
not sure about the pulleys... the belt was recently replaced, within the past 4000 miles. could it be that the new belt is more firm that it wore out the pulleys? the engine has 229k without a rebuild... not sure on records previous 214k.
Old 07-29-2007, 09:45 PM   #4 (permalink)
MudHippy's Avatar
Same noise turned out to be both timing idler pulley bearings on mine, the water inlet and the tensioner. Not that I didn't initially panic I think it was my cams too, I did but it wasn't. Someone had put a new belt on mine before I bought it without doing the pulleys, could have been done then, I wish at least. New belt won't hurt the pulleys unless they're goin' already.
__________________
Sonoran Steel Early IFS Truss
Your IFS is SPINELESS without it
SonoranSteel.com
I'm Cuckoo For YOTA Trucks!
MudHippy is offline
Old 07-29-2007, 09:50 PM   #5 (permalink)
locked stock 84's Avatar
Send a message via AIM to locked stock 84
It sounds like belts to me!
__________________
My rig: slow 84 longbed 22r, locked in the rear, headers, bed riddled with cancer, and mt 31's
Have locker, will travel.
locked stock 84 is offline
Old 07-29-2007, 09:51 PM   #6 (permalink)
MudHippy's Avatar
Another possibility.
__________________
SonoranSteel.com
MudHippy is offline
Old 07-29-2007, 09:51 PM   #7 (permalink)
most likely a result of the new belt being of a different tension?
Old 07-29-2007, 09:52 PM   #8 (permalink)
i hear the noise more from behind my timing cover... most likely my timing pulley and idler.. I would suspect, thats why i initially thought it was the cams
Old 07-29-2007, 09:55 PM   #9 (permalink)
MudHippy's Avatar
The tensioner is designed to keep the belt at a consistent tension. A bad tensioner, or improperly installed could put extra stress on the pulleys. What I meant was if they hadn't been inspected thoroughly when the new belt was put on they would be on the way out regardless. As was the case with mine. The water inlet is a job to replace, so I can see not wanting to replace that one. The other is pretty quick.
__________________
SonoranSteel.com
MudHippy is offline
Old 07-29-2007, 09:59 PM   #10 (permalink)
the water pump was recently replaced, does that include the inlet?
Old 07-29-2007, 10:24 PM   #11 (permalink)
MudHippy's Avatar
No, the water pump also has a pulley that the timing belt rides on though, it drives the pump.
__________________
SonoranSteel.com
MudHippy is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3vze cam pulleys sroot1 86-95 Trucks & 4Runners 2 02-19-2007 09:32 AM
CAM TORQUE SPECS 3Vze morgan4run Maintenance & Repair Archives 2 09-29-2005 08:51 AM
3vze cam seals leaking justanother4x4 Maintenance & Repair Archives 1 06-21-2005 07:42 PM
3VZE 3.0 Cam seals fnrunner Maintenance & Repair Archives 8 05-06-2005 08:21 AM
2009 InternetBrands, Inc.
