3.0 starter location and removal.....
Old Oct 25, 2010 | 05:20 PM
YFZsandrider's Avatar
The starter in my '93 3.0 pickup has finally crapped out on me! I was looking through this thread...
https://www.yotatech.com/forums/f116...issues-221046/
Someone responded that the starter is located behind the oil filter??? I know it is on a 22RE, that would put the location of the starter on the driver side.
Where exaclty is it, and what's the best way to reach it? I've read about an access panel in the fender, where exactly is that?
Old Oct 25, 2010 | 05:57 PM
MudHippy's Avatar
Here's what it looks like with the starter access panel out of the way(and possibly with a body lift installed, looks like it to me anyway). It's located, on the passenger's side BTW, near the center of the pic here.
Old Oct 25, 2010 | 06:13 PM
TNRabbit's Avatar
It's a total PITA to get out, but piece of cake otherwise to put new contacts in it. You can get them from your local parts store for about $11.
You need about 6 socket extensions to reach the: 1) rear bolt, and 2) front bolt. The front bolt is accessible from between the front valance holes & the rear, possibly with a swivel, from underneath & several extensions.
DO NOT buy the cheap-@$$ Advance/NAPA/etc. lifetime warranty starter. Keep your original & replace the contacts. use a Dremel to GENTLY buff out any pits in the plunger.
Old Oct 25, 2010 | 06:16 PM
xxxtreme22r's Avatar
yes It is a PITA to get out. 92Toy can confirm it took me about 30-45 minutes on his to get it out. FYI it will come out in that same hole that is pictured above if you get those wires and other lines out of the way by moving them aside.
Old Oct 25, 2010 | 06:19 PM
4Crawler's Avatar
Yep, passenger side, see below for more info:
- http://www.4crawler.com/4x4/CheapTri...eresTheStarter
Old Oct 25, 2010 | 07:35 PM
REDYOTA's Avatar
fished mine out the passenger fender well, remove the stabilizer to reach the front bolt, becarful with the clip etc.
30 to 45 min thats got to be a record iwas still using normal cuss words at that time frame, goes in easier than it comes out
here is my rebuild link, sorry no location or removal pics but good rebuild pics
https://www.yotatech.com/forums/f116...er-fix-216099/
Old Oct 25, 2010 | 07:56 PM
redcobragt's Avatar
Mine was clicking, so i pulled it out to take to kragen to check out, it was fine, swapped out the neg cables and still clicking, put a new battery and wholla, damn, sometimes the most obvious things just slips the mind, so with a 3 inch bodylift was not that bad taking out the starter.
Old Oct 26, 2010 | 05:20 AM
99blackSE's Avatar
I've done it a couple of times, once you do it the first time it's much easier. Also helps if you have skinny little arms and hands haha.
Old Oct 26, 2010 | 09:44 AM
sb5walker's Avatar
Not sure if it's still the case on the 93, but on the 89 3VZE with manual tranny there's a possible gotcha. On the early trucks there's one bolt that goes from the front, through the starter flange, and into soft aluminum threads on the bell housing. It's near the top, IIRC. Problem is, on the early trucks anyway, Toyota used a too-short bolt that only grabs about half of these threads. When I changed the starter on mine, I found the previous owner had stripped those threads. I've read of others who did the same thing. On mine, I just replaced the bolt with a longer one that was able to engage the unstripped threads further in. Suggest doing that even if the threads are not yet stripped on yours, if your truck has the same situation.
Old Oct 26, 2010 | 03:04 PM
my last '94 was that way as well... prev. owner used a ridiculously long bolt tho.
Old Oct 27, 2010 | 01:26 AM
Update-
FYI for anyone trying this in the future.... If you remove the access panel in the passenger side fenderwell, you CAN remove the starter without moving the clutch slave cylinder, or jacking the passenger side of the motor.
I acccoplished the romoval and install by using a short 14mm socket, then a wobbly, then 2 long extensions. Pull the top bolt facing rearward at the bellhousing, and the lower bolt facing foreward at the starter. There is a positive terminal wire that must be disconnescted as well as a small plug.
The starter can be removed through the access opening if you move the engine harness to the side, it seems like it won't work, but it will. My truck is completely stock with no body lift, and even has the A/C lines coming from the compressor which slighly get in the way. It can be done.
Old Mar 31, 2011 | 08:39 PM
mick cassidy's Avatar
yup i agree it is a 20 min job to get out and a 45 min job to put it back in on my 91 remove the pass side wheel then get in there through the access panell dont forget to disconnect the battery or you will have a sparks show !!! try to get a friend to help it will cut the time in half . the starter contacts wear down they are copper i get mine from online toyota of dallas $20 for oem my starter cranks like a mo-fo now id say replace them every 5 years for a totally reliable system
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
4x4-runner
Aug 30, 2015 08:55 AM
4x4-runner
Aug 2, 2015 09:24 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
