3.0 Plenum Removal
Old 11-28-2011, 12:30 PM
B4Runner's Avatar
3.0 Plenum Removal
Hey Guys, I just have a few quick questions.
I'm in the process of removing my plenum.
I have done some research. According to the pic int he following link, I have removed all necessary hardware: https://www.yotatech.com/forums/f120.../#post51814140
All 4 main bolts, 2 (1 front, 1 rear) nuts, EGR, and all other nick-nack wires and such on the pass. side are removed.
I am able to pry the pass. side of the plenum up just slightly, but I can't get the driver side to break free.
Have I forgotten to remove something? Or am I not doing something right?
Thanks to all who pitch in! This is my first time taking any engine apart.
Old 11-28-2011, 02:34 PM
RRogers's Avatar
That should be it. Unless the throttle cable is hanging it up?????
Old 11-28-2011, 02:49 PM
nerdlip's Avatar
There should be 2 more bolts, i believe you have to remove accelerator cable bracket to access them.
Old 11-28-2011, 04:14 PM
93toyrunner2's Avatar
There are 6 bolts and 2 nuts to remove it. 4 on top, 2 nuts and 2 bolts on the far drivers side below the top level. You also have to disconnect the coolant hose connected to the throttle body, and on the passenger side, disconnect the big hose for the PAIR valve, which is towards the pass side rear, underneath. Throttle cable and cruise control cables need to be off. Also remove the Fuel pressure regulator fuel line connection to the plenum metal tube that runs underneath the front of the plenum to the pass side. Loosen gas cap to release fuel pressure before!
Old 11-28-2011, 06:42 PM
RRogers's Avatar
Originally Posted by 93toyrunner2
There are 6 bolts and 2 nuts to remove it. 4 on top, 2 nuts and 2 bolts on the far drivers side below the top level. You also have to disconnect the coolant hose connected to the throttle body, and on the passenger side, disconnect the big hose for the PAIR valve, which is towards the pass side rear, underneath. Throttle cable and cruise control cables need to be off. Also remove the Fuel pressure regulator fule line connection to the plenum metal tube that runs underneath the front of the plenum to the pass side. Loosen gas cap to release fuel pressure before!
You are correct. It has been quite a while since I have had the plenum off of mine.
Old 11-28-2011, 07:08 PM
truckmike26's Avatar
I just did this a few months ago to change a leaking pulsation damper (change that while you're under there because they often fail -- it's on the passenger's side fuel rail at the back). As mentioned just above, my money's on the rear coolant hose to the throttle body hanging it up. It's hard to see. By the way, an O.E. pulsation damper cost me big bucks ($200) from the dealer but Rock Auto has one for around $90 before shipping.
Old 11-28-2011, 10:14 PM
B4Runner's Avatar
Nope, that's completely out of the way already.
I will check around that area.
A total of 6 bolts might explain my difficulty. I got the 2 nuts and the 4 bolts on top. Now I've just got to find those 2 others.
Thanks everyone!
Old 11-29-2011, 02:28 PM
drmix's Avatar
Check here at the bottom of pg EG2-55.
http://www.ncttora.com/fsm/1993/engine/68cylinder.pdf
6 bolts and two nuts
Old 11-22-2012, 03:33 PM
mikeljeremy2's Avatar
I got water in the cylinder.....
Posted in wrong forum.
Last edited by mikeljeremy2; 11-22-2012 at 09:12 PM. Reason: I posted in the wrong forum.
Old 11-22-2012, 04:51 PM
brianh699's Avatar
Originally Posted by mikeljeremy2
I needed to replace the motor in my 96 Tacoma, first time for me, and like a dummy forgot to label the hoses. After putting in the motor and using diagrams and a Haynes book for the vacuum lines and throttle body connections, the truck fired up. But shortly after died and didn't want to start. After pulling the spark plugs I found water in a couple cylinders. I really don't think the head gasket is blown, I feel I didn't hook up the water by-pass line in the right spot and it's pumping in through the plenum. Is there a diagram to go by to make sure that the water, and water by-pass lines are connected where they are supposed to be?
You should start a new thread for this question your in the wrong forum and you'll get better results with a new thread.
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
tobylab
01-18-2016 07:06 PM
jahsermon
08-04-2015 08:35 AM
tobylab
07-12-2015 12:53 PM
Quick Reply: 3.0 Plenum Removal
