2wd w/Dana 30 swap for light duty use
Old 04-18-2014, 04:39 PM
superex87's Avatar
So I have a 88 2wd Pickup. The truck is in good shape and only needs the front end worked over. Mainly ball joints and bushing ect.
This truck is my DD, I will not be using it for anything except driving on the street and some grass/ dirt field use to get to friends bonfires ect. No rock crawling or major off-roading.
My idea is to slowly build up the truck to make a suitable snow/ field truck on a budget. I can weld and fabricate basic things.
The plan is to use a dana 30 solid axle with ruf springs and a divorced transfer case, I want to reuse as many of the parts as I can. The divorced case would allow the use of driver drop axles. I have not decided on what transfer case I will use.
What is your opinion on this idea and in what ways can it be improved within financial reason?
Old 04-18-2014, 07:01 PM
scuba's Avatar
Improved? A $200 Toyota axle with a knuckle rebuild kit and a used Toyota w56 w/ an RF1A transfercase.
Hell, buy a newer w59 and get a marlin adapter and use the RF1A transfercase. You'll have a newer trans with the proven gear drive case.
I don't recommend putting Jeep parts on a Toyota and not just because of stigma.
D30's are a waste of time.
Old 04-18-2014, 07:20 PM
JasonYota's Avatar
The only divorce transfer cases I can think of off hand are Atlas, NP205, and I think Dana 300.
Like scuba said use toyota parts. You can easily find a 4wd trans and transfer case. Front toy axle, I wouldn't say easy but there are plenty out there.
If you do get a toyota front axle you will have to get a 4wd rear axle also to be 6 lug, and get matching wheels.
Old 04-18-2014, 10:04 PM
rattlewagon's Avatar
What size tire are you going to be running? Im with these guys on calling you crazy for running a tiny axle such as a d30, but for a mostly stock truck a d30 should hold up pretty well. They can be built to take the abuse of 35s reliably.
You can get adapters to turn a toy case into a divorced case. Sammy cases are divorced, What about a drivers drop chain drive case from a tacoma?
Plans for the rear? d44? 8.25? Youll want to match the new front lug pattern I assume?
You should really just get a 4wd trans/t case and run a toy axle...
Old 04-19-2014, 01:09 AM
91 4Runner's Avatar
No need to worry on the bolt pattern. The 2wd shares the same 5 bolt pattern as a jeep.
Old 04-19-2014, 10:49 AM
superex87's Avatar
I really would like to use a Toy front axle but I'm having a hard time find one local to me.
Would a land cruiser axle work?
I know they are wider but I would be ok with that. I friend of mine may have a set of cruiser axles for sale (front and rear).
If I could get them for 300 or so would that be a worthy investment?
Old 04-19-2014, 10:54 AM
JasonYota's Avatar
Any axle will work, depending on your fab skills. Seems like a good deal if there in good shape
Old 04-19-2014, 10:59 AM
superex87's Avatar
Well the axles have been out in the rain for a long time.....other than the knuckle balls rusting/ pitting they should be ok?
Old 04-19-2014, 11:01 AM
JasonYota's Avatar
Also keep in mind they will have spots for coils and not leaf spring perches.
Old 04-19-2014, 03:56 PM
What year land cruiser? 40 and 60 had leafs. Does the front axle have drum breaks? Landcruiser axles would be very cool.
Old 04-19-2014, 03:57 PM
JasonYota's Avatar
True, I was thinking 80 series.
Old 04-19-2014, 04:01 PM
Even that would be sweet. HP front diff and possible e lockers...
Old 04-20-2014, 03:37 AM
superex87's Avatar
Im pretty sure they have leaf perches but i am unsure what series they are off of. How would I identify them?
Old 04-20-2014, 04:00 AM
LC Faq: http://www.pirate4x4.com/forum/toyot...-diff-faq.html
smthwsn357
05-01-2024 07:28 AM
ashersullivan88yota
01-18-2022 05:37 PM
msane99
07-17-2015 10:13 AM
Johntom240
7
07-13-2015 12:18 AM
hexrain
07-12-2015 01:13 PM
Quick Reply: 2wd w/Dana 30 swap for light duty use
