2wd starter vs. 4wd starter
Old 11-16-2009, 07:56 PM
redneckandy's Avatar
is the starter on a 2wd and 4wd pickup the same? the flywheel on the 2wd is smaller and i put my old starter from the 4wd on there just wonderin if itll work
Old 11-17-2009, 12:07 AM
wyoming9's Avatar
Red face
It should work I have interchanged starters between Celicas and 4x4 vehicles
Easy way to check go on line and compare the part numbers at Napa autozone who ever
Old 11-17-2009, 04:29 AM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
Pretty sure Toyota used the same 1.4kW starter on all 22R(E/ET)s, regardless of 4x2 or 4x4.
Old 11-17-2009, 05:25 PM
Thumbs up
thanks guys. just started it up today for the first time since i swapped the engine. worked perfectly
Dakotaneu
08-15-2015 07:24 AM
yipyip45
08-06-2015 02:05 PM
landrunner
08-05-2015 09:18 PM
clok
08-01-2015 09:42 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 2wd starter vs. 4wd starter
