22rte cold start issue
Old 04-02-2011, 03:13 PM
jeetS's Avatar
Have to crank it about ten revs then let it sit for 5 seconds then it tries to start and usually does within five more tries.
ONLY when the engine is cold. When warm it runs and starts like a champ.
about 5k miles on rebuild, done this ever since the rebuild. dont know if it did this before the rebuild.
once it starts it runs smooth as well.
Replaced cold start time switch, cold start injector....tryin to figure out where to go from here.
truck is basically stock
86 4x4 turbo manual
Old 04-02-2011, 06:24 PM
weaselman's Avatar
idle air control valve stuck?
Old 04-03-2011, 03:28 AM
mldave's Avatar
Had a similar thing on my 86.Fuel pressure leak somewhere on the fuel rail?After endless forums and web searches,had a friend bypass the CSI switch.Just flip the toggle switch and first time every time it fires up.You might also have a fuel damper leak,as I had.
Old 04-03-2011, 03:57 AM
Flash319's Avatar
Check your Circuit open relay. Try jumping B+ and FP in the diagnostic terminal to force the fuel pump on. If that fixes it your COR relay may be going bad. She's an old girl....
Old 04-03-2011, 09:20 AM
jeetS's Avatar
haha yup she is an old girl! I did jump the connector to make sure the pump turned on right away...I could hear it whirring in the tank...no change.
tell me more about the fuel damper....
thanks guys
I might try another CSI switch...It came out of a 87 supra...and the supra started up no problem before it got scrapped so i just assumed that it was working properly...
Old 04-03-2011, 09:34 AM
mldave's Avatar
http://www.google.com/search?source=...5820d0512&bs=1 from what I've read most of the CSI switches are somewhat different in their electrical readings.Also the thermo switch to the right of the CSI might be bad or wires loose/corroded.Like mentioned earlier,bypassing the CSI switch was the easiest,though not the book way to solve that.Not mechanical at all,just throwing out some things to you that I've read.
Old 04-03-2011, 03:18 PM
jeetS's Avatar
the thermo switch to the right of the CSI?? do you mean the efi temp sensor that is beside the cold start time switch?
Old 04-03-2011, 03:30 PM
mldave's Avatar
That's the one........
Old 04-03-2011, 03:37 PM
jeetS's Avatar
would that have anything to do with hard starting? I thought that talks to the ecu and doesnt have anything to do with cold starting... I will look more into the time switch....hopefully its not a wiring problem...if thats the case and its somewhere in the middle of the harness i'd probably take your approach and bypass that switch lol
what do I need to feed the CSI to fire it? just 12v?
Old 04-03-2011, 04:35 PM
mldave's Avatar
JeetS,just another thing I read about the thermo temp switch,as mentioned earlier I/m not mechanical and did not do the bypas switch either...if you do the bypass make sure the switch is rated for car/truck usage.http://www.google.com/search?source=...=&oq=22re+cold.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: 22rte cold start issue
