22re Oil pump shim/pressure improvement?
Old 01-23-2007, 02:56 PM
Barnstormer's Avatar
Is it possible to increase the oil pressure by shimming the relief valve? I have done this on other motors (VWs and such), and it looks like it might work for the 22re. There is an external hex headed bolt on the oil pump that contains a spring and check ball (I am pretty sure)
Would a stiffer spring or shim increase the oil pressure? I'd like a little more, as at 230k miles mine is a tad lower than I would like.
Any ideas?
Thanks!
Old 01-23-2007, 04:00 PM
Flash319's Avatar
Get a new pump for Engbuldr.com for around $50 bucks. That is better then screwing with the heart of your engine. I am not sure that there is a pressure relief on these.
Old 01-23-2007, 10:40 PM
tkm433's Avatar
Any ideas?
Thanks!
You might want to check this out
http://www.toyotacatalog.net/M1WebGe...2-1683F2407782
Old 01-24-2007, 09:19 AM
Originally Posted by tkm433
AH HA!
That might be just the thing.
Thanks for the link!
B
Old 01-24-2007, 09:20 AM
dcg9381's Avatar
Yes.. It works. If you have a look at the front of my motor, you can see I'm running one. The pump is a high volume/pressure pump provided by DOA:
http://lakebox.dnsalias.com/photos/1...nginefront.jpg
LC sells a shimmed by-pass also.
bigjstang
08-25-2021 12:41 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 22re Oil pump shim/pressure improvement?
