YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-04-2006, 01:18 PM   #1 (permalink)
22RE idles rough, any ideas?
Here's the story, in short: My 94 22RE was missing on the 4th cylinder and running like crap. The injectors were in bad shape, I sent them to RC.engineering and the report said that 2 and 4 were at 19cc and 2cc, they are now back to 180cc with new rings and seals ect.. I put them in and the engine fired right up, 4 is firing but the idle below 5k is still really rough and the block shakes quite a bit. I have;
1) new plug wires
2) new cap and rotor
3) new NGK plugs
4) NO check engine light/ no codes
5) d/c'd the EGR valve, no change
6) sprayed contact cleaner looking for a vacume leak
7) not replaced the O2 sensor (see 4)
8) new fuel filter about 10k ago
9) new timing chain at 120k (now at 195k)
Why is it still running like crap? any ideas, I saw a lot of good info on this site and hope someone has an idea.
Thanks much
Striker
Striker is offline
Sponsored Links
To remove this ad, register today!
Old 09-04-2006, 04:25 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
Welcome to YotaTech.... did you hook up the injectors right maybe missed placed a vaccum line ?
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 09-04-2006, 04:39 PM   #3 (permalink)
Send a message via AIM to Firefightertaco
try some seafoam from your local autoparts store, its just like carb cleaner just search the forums for seafoam and u should find a lot of stuff.
__________________
JP
2003 Tacoma White TRD
E-Locker, 3" toytec lift, 2" RB BL 10,500 milemarker,
32/12.50 BFG MT on black wheels
UWS black toolbox, and working on more.
2007 fj cruser (moms)
86 4runner 22re auto 3" leafs 32bfg mts
Firefightertaco is offline
Old 09-05-2006, 02:16 PM   #4 (permalink)
Thanks for the ideas, I never disconnected any vaccum lines, just the radiator and fuel. I was able to flip the manifold up and access the injectors. How about the cold start injectors? someone told me these could be dripping, anyway to diagnose this? Over 10k RPM it sounds smooth and had plenty of power but at low idle it still shakes pretty bad I am at a loss. If anything is worht trying let me know, found some seafoam, haven't tried it yet.
Striker is offline
Old 09-05-2006, 02:31 PM   #5 (permalink)
rentedmule's Avatar
I had a distributor wear out and cause similar symptoms on a non-yota. took forever to diagnose - i guess it's not something that usually comes up. The dealer changed all the ignition parts and most of the sensors before they figured it out and fixed it with a $50 junkyard part. maybe worth checking?
__________________
'93 4runner, 3.0, 31x10.5's, OME900's.
'84 Xtracab, 22R, flareside, 6" lift, 33x12.5's
'03 Sonoma 2wd, supercharged 4.3L@9psi
'81 Turbo Trans Am, WS6, 301V8@9psi
rentedmule is offline
Old 09-05-2006, 02:58 PM   #6 (permalink)
Elton's Avatar
Quote:
tell me thats a typo
__________________
Elton is offline
Old 09-05-2006, 03:17 PM   #7 (permalink)
Tiger Paw's Avatar
Might be off the wall, but did you check your motor mounts. If they're worn, they'll cause your engine to rock quite a bit, which has a tendancy to throw things off balance.
__________________
1989 Toyota 4runner DLX, 22re, 4WD, on 31x10.50x15's(I'm sitting soooo high), Smittybuilt double-tube rear bumper, extended diff breather mod (front and rear diffs), Cobra 29 CB, 4ft Firestik, OME Nitrocharger shocks
Active member NAHC and DU
"Anybody ever tell you those look like two raw eggs hanging from a nail?"-What not to say to a chick at Bike Week
Redneck's last words-"Hey Bo, watch this!
Tiger Paw is offline
Old 09-05-2006, 03:29 PM   #8 (permalink)
rdharper's Avatar
Broken valve spring?
__________________
Richard
"Science by consensus... is not Science." Richard Harper -1988
'94 Toyota 4Runner V6 3L 157K miles 14mpg
'85 Toyota 22rec 4WD SR5 LB PU 207K miles 18mpg
'08 Honda Ridgeline RT 1.5K miles 16mpg
'06 Honda Rincon ATV 289miles/60hrs 22 mpg
rdharper is offline
Old 09-05-2006, 06:32 PM   #9 (permalink)
trythis's Avatar
I didnt see anything about your TPS. That thing causes so many problems if it is out of adjustment. If it si bad, you can't time the engine or set idle speed, and from there it is hard to fix anything.
I got the best results solving rough idle by replacing my TPS, cleaning the throttle body and the cheapest of all was changing out all my vacuum tubes. After that, it was pretty darn smooth. Before I did that work, the vibration hurt my legs.
__________________
89 DLX xtra cab 4x4 22re Auto with 170,000, 225 75R 15, Stock except, "new" 2000 toyota cd/radio, rear speakers hidden in the back seat, SR5 instrument cluster, factory clock. Added an aftermarket cruise and some matching blue door pockets! New timing chain with Engine builders front end rebuild kit. Tokico RT trekmaster shocks <-like them.
I found the turtle in my yard, after mowing over it and it was fine! Old toyota trucks are like turtles: slow, steady and durable.
trythis is offline
Old 09-05-2006, 09:03 PM   #10 (permalink)
yota_krazy's Avatar
it would be a good idea to run a compression and leakdown test to make sure things are internally sound. Also if you have a vacuum guage you can hook it up to a vacuum line that goes directly to the intake and watch the reading. I believe it should be around 21 inches of mercury. (which is what vacuum is measured in) It should not fluctuate, this can also tell you about the internal engine parts. good luck bro
yota_krazy is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re idles but cuts out. 4runnerD 86-95 Trucks & 4Runners 5 02-17-2007 08:23 AM
Rough idle on swapped 22re... Any ideas? NotMatt 95.5-2004 Tacomas & 96-2002 4Runners 0 06-10-2005 08:13 PM
83 truck, idles rough, stalls fryeguy1983 95.5-2004 Tacomas & 96-2002 4Runners 7 07-31-2004 10:32 PM
22re idles a little rough and smells rich wifesaysimadumbass 95.5-2004 Tacomas & 96-2002 4Runners 12 07-16-2004 06:41 AM
3rd Gen idles a little rough DrummerDaveB 95.5-2004 Tacomas & 96-2002 4Runners 12 06-22-2004 06:43 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
