22RE Hoses and vacuum line pics needed please
Trying to button everything on my 22re, all thats left I hope is hooking up the vacuum lines and other hoses and then some other things. I tried to follow the vacuum diagram in the chiltons as best I could but am missing something somewhere and this is what I have left to figure out.
This is on top of the throttle body. I'm not sure where this goes:
This one is on the bottom of the throttle body:
and this is under all the other hoses and air pipe:
I am lost on those. I also have this part left that I need to figure out where it bolts down too. This is in-part of the bundle that goes under the intake, and I think it bolts on the side closest to the pass. fender of the air intake chamber, but again, have no clue. It looks like its a ground wire of some sort. maybe bolting to the top of the valve cover is another thought?
I've searched a few threads, looking for photos of the 22re, but cant find any clear enough for me to decipher.
this is what i've been looking at, but i can't make out everything due to the distance
https://www.yotatech.com/forums/show...0&postcount=18
thanks. the last one, looks like theres a connector that goes over it, i just can't seem to find it. do you know whats on the other end of that?
Not sure about your item in pic 3 of your post. Flashes pic and mine below are about halfway back on the head, but it is an electrical connection, not vaccum. But the other surrounding hoses look right.
Then there is this sensor below the TPS that has vaccum lines, but if that is what you're looking at yours is broken off. If that is what you are looking at, I will try to get you better pics.
The wire you show in your last 2 pics didn't have a nut and bolt like yours on my truck. It just attaches to the nut and stud on the back/bottom intake like so.
Hope this helps.
Mike
Hope this helps.
Mike
That is a Temp sensor switch that the connector is plugged into. Not sure if it is for the dummy light or ECU but my guess it is just for the dummy light. BLKNBLU has another smog thing or something that that first line goes to then to the power steering. Not sure what it is. My truck is an 89 and bought in Canada.
thats the one i'm trying to find. where does that wire go to? I have a feeling its just dangling somewhere but I can't find it.
I got all the other ones hooked up. The ones that look broken on mine, never had a sensor (since I've owned it atleast) so it looks right to me, lol.
zd92655
03-06-2022 12:58 PM
