22Re feeels like it has turbo lag?
Old 01-07-2006, 05:55 AM
powerwagon67's Avatar
I have a 95 truck with the 22RE and 125,000 miles on it. The engine when cold or when it warms up has this hesitation that feels like turbo lag especially when acceleration in 2nd and 3rd gears and I don't really notice it in first gear. I have cleaned the TB assembly,replaced the plugs and wires,cap and rotor (all factory parts) and adjusted the timing to 5 deg. BTDC as it recommends but its still there. I also have checked for vacum leaks with propane and carb cleaner but didn't notice anything. Any ideas would be helpfull. Thanks
Old 01-07-2006, 10:20 AM
kyle_22r's Avatar
did you make sure to jump the correct terminals on the diagnostics box before you set the timing? if not, you have severely retarded the timing and it'll drive like a dog.
Old 01-07-2006, 11:22 AM
Yes I jumped the terminals as the manual had specified.
Old 01-07-2006, 02:07 PM
waskillywabbit's Avatar
Mine did that and it was the TPS and the AFM. Both were replaced and no more problems.
Old 01-16-2006, 03:53 PM
I checked the resistance of the TPS and the AFM per the manual and it seems to check out OK. Any other ideas before I take it in to the shop.
Old 01-16-2006, 05:25 PM
Yamaha+Toyota=Fun's Avatar
My truck does this a bit too. It doesnt really bother me much so I have never tried to figure out what is wrong.
Old 05-03-2011, 11:06 AM
automated11's Avatar
Did anyone figure out what this issue exactly was? Mine is having the same issue right now. Kinda feels like turbo lag... No check engine lights.
Old 05-03-2011, 11:55 AM
blake.nemitz's Avatar
try puting the timing at 10* at our altitude we have less effective compression and can get away with a higher base. i run mine at 15* and can run cheap gas without a ping if i want. if you cant figure it out pm me and ill come help you out
Old 05-03-2011, 12:01 PM
Sweet Thx
Old 05-06-2011, 04:52 AM
I took the base timing to 10deg and it made a WORLD of difference! Thanks for the help.
montanatruck
02-26-2017 07:07 AM
God's Bounty Hunter
10-23-2015 09:44 AM
RatOmeter
10-22-2015 03:17 PM
toofly1999
07-25-2015 07:09 PM
mlavery85
07-12-2015 10:33 AM
Quick Reply: 22Re feeels like it has turbo lag?
