22r running cold.
Old 11-14-2014, 01:24 PM
twoyotas86's Avatar
22r running cold.
No matter what I do my truck stays in the bottom third in the temp gauge. It's been like this on 2 separate engines. The only thing I could think of is that maybe it's running to rich. But for it to be running that rich I would think there would be other more noticable symptoms.
Old 11-14-2014, 01:52 PM
RJR
RJR's Avatar
More likely an inaccurate gauge, or a bad thermostat.
Old 11-14-2014, 04:03 PM
twoyotas86's Avatar
It was on 2 separate engines with different thermostats. And I've replaced the cluster. I guess that could be a possibility.
Old 11-15-2014, 01:06 AM
Odin's Avatar
From a lot of reading on this site I understand the water temp gauges on these trucks aren't that accurate and a low reading is somewhat common.
Did you transfer the same sending unit from one engine to the other?
Are/were you using a 180 thermostat in both engines?
Old 11-16-2014, 07:46 AM
shafner30's Avatar
Yo
I run the 180 thermostat my truck has 430,000 miles on it it runs like a champ keep the 180 on it
Old 11-21-2014, 11:35 AM
LADave's Avatar
There's a pinned or recent thread on fixing temp gauges. They have two coils with very thin wire prone to breakage; then your readings will consistently be off.
bigjstang
08-25-2021 12:41 AM
sandyota
02-04-2021 11:16 AM
Jonny246
07-12-2015 04:51 AM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22r running cold.
