| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22r/22RE hybrid engine questions - PICS ADDED!! Need Help
__________________
1987 4Runner 22RE 291,000 miles - 63" chevy swap, Ball Joint Spacers, DT shocks, Downey IFS truss, differential breathers, 33x10.5 BFG MT KM's, rollbar mounted highlift. Soon to come: aussie locker in rear. Last edited by Extremesolo; 08-27-2008 at 04:09 AM. Reason: added pictures |
#2 (permalink) | |
Intake ports on a 22R head are round where 22RE heads are pear shaped.
__________________
'88 4Runner - 22RE - 203K - Fresh Rebuild, .20 over, 268* cam, OS stainless valves, LC Header, 2.25'' exhaust. LC Adjustable Camgear Aussie locker (rear), Lincoln Locker (Front) 4.88s, BJ Spacers + AALs, under 32x11.50 BFG ATs Quote:
#3 (permalink) |
you're gunna have to switch over all the efi stuff
more than you ever wanted to know about the difference between the blocks and heads on the 22r, 22re, and 20r's |
#4 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
since you say it's a 22re block, the block should bolt to the trans and frame just fine and should not have any wiring issues as long as all the existing parts on the truck are used / transferred to the hybrid block / head.
the 22r head does not have a intake manifold bolt boss or two that the 22re head has, so the stock efi manifold won't be properly secured to the head. http://www.toysport.com/Technical%20...tech_notes.htm has a description about other things that are different between 20r/22r/22re's.
__________________
Quote:
Insomnia: it's a way of life.
#5 (permalink) |
I have a few pictures of the engine. I am deferring to the experts to let me know exactly what I am dealing with. I just need to know if it will bolt up to my 87 runner and the existing EFI system without modifications? Also I would like to possibly rebuild the engine so I would need to know exactly what block and head I am dealing with. Thanks again for any help. Hopefully the pics are clear.
__________________
1987 4Runner 22RE 291,000 miles - 63" chevy swap, Ball Joint Spacers, DT shocks, Downey IFS truss, differential breathers, 33x10.5 BFG MT KM's, rollbar mounted highlift. Soon to come: aussie locker in rear. |
#6 (permalink) | |
Yes it will. I cant tell you for sure what year exactly, or if the harness will be the same, but it will fit.
That looks like air injector near the exhaust side, I know I had it in my '88, but it stopped at '89. So it should bolt up and it looks like your harness should work too
__________________
#7 (permalink) |
It looks like a 83-84 Celica 22re engine. They used the older tall deck blocks and large combustion chamber heads. Very reliable engines! Look at the block on the driver’s side just behind the motor mounts. If it’s an 85 or newer short deck block it will have the embossing for the turbo oil line. If it doesn’t, then it’s the older tall deck block. Compare this to your old 87 22re which will have this. Either way, this engine will work just fine. However you will need to use all of your 87 EFI parts.
ccannon222 Last edited by ccannon222; 08-27-2008 at 08:39 AM. |
#8 (permalink) |
In order to rebuild it, will I need to know exactly what it is or can I order the master engine rebuild kit from engnbldr and be good to go? Basically will the kit be different for a celica 22RE than a runner 22RE?
__________________
#9 (permalink) |
Also had one more picture, don't know if it will help or not.
__________________
#10 (permalink) |
You will need to know if it is a tall deck (81-84 22r/re) block or a short deck (85-95 22r/re) block. You know that the head is an 81-84 so you will need to order parts for it. I would assume and from the pictures it looks like a tall deck block. Putting a 81-84 22r/re head on a short deck block requires a lot of modifications to get the timing chain to work. Same mods that people have to do to install a 20r head on a short deck block.
Check for the protruding embossing on the drivers side of the block. If you need a reference, compare it to your 87 motor which will have it. It kinda looks like a Mickey Mouse head. ccannon222 |
#11 (permalink) |
forgot to attach pic last time
__________________
| Tags |
| 22, 22r, 22re, ball, block, celica, engine, gasket, hybrid, identification, installation, joint, taller, truck, work |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 20R/22R Hybrid | 84'22r | Pre 84 Trucks | 2 | 04-27-2008 05:45 PM |
| 22r/20r hybrid auto tranny questions. | wimpywade94 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 02-16-2008 08:43 PM |
| 1986 toyota engine ID 22r or 22re | Johnny Reb | Newbie Tech Section | 3 | 08-27-2007 06:21 PM |
| 22R to a 22RE Questions/ or mods?? | nightsurfride | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 04-12-2004 01:06 AM |
