1995 4runner has no power between 35 mph and 55mph
Old 05-31-2006, 06:36 AM
subprime's Avatar
Automatic Tranny
3.slow
I can get good acceleration from 0 to 35 if I choose to put the pedal to the metal. But when it hits 35, it takes forever to get up to 55 mph.
It scares me when entering a freeway and I cant match speeds with the flowing traffic. its worse when the meters are on (im in CA) and I come from a dead stop, but the freeway traffic is going 65 mph.
Is this common? Is there a fix?
Old 05-31-2006, 01:40 PM
Elton's Avatar
umm you have a 3.0 and a auto its always going to be slow they dont call it a 3.slow for no reason
Old 05-31-2006, 02:34 PM
4mydogs's Avatar
Need more info, Sub. Has it always been this way? Or are you a new owner and just getting used to/don't know your vehicle yet? Does it seem to be missing? Does it stumble at a specific RPM?
Old 05-31-2006, 03:59 PM
trythis's Avatar
I don't know how relevant this is, but I have the 22RE auto. I had the exact same problem and I tried all the tune up stuff and finally checked out my Throttle position sensor (TPS). It never snapped back into the 0 position and the spring inside was worn out. I replaced it and now I feel like I am driving a fully functioning vehicle. It uses all the gears instead of trying to lug up to speed in overdrive. I actually feel it use 2nd and 3rd gear when moving on the on ramp to the highwway. Before it would only switch into 2nd if I floored it and then snap back into overdrive. (of course I don't even know if a 3.0 has a TPS)
Old 06-01-2006, 12:08 PM
subprime's Avatar
I just bought it. 186k miles. It was a daily driver from the previous owner. Drove about 80 miles per day in bumper to bumper traffic.
I guess it is missing the 2nd and 3rd gear. Once i get it up to 55mph, theres a lot of power up to 80 mph.
Old 06-01-2006, 04:46 PM
toyotaoffroad91's Avatar
pull your engine codes and see if the o/d light blinks, could be a bad solenoid in the tranny which are common on the a340's but easy to change
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-08-2015 12:05 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 1995 4runner has no power between 35 mph and 55mph
