1992 4x4 4runner Real Main Seal
Hey, Guys! I Need some Advice on How to change my rear main Seal? is it gonna take alot of work of changing the Seal? Please I need Advice! Thanks!
changing the seal is not hard. remove the trans, then remove the clutch and flywheel if MT or the flex plate if auto. the RMS is right there around the crankshaft. I have a hooked shaped tool that i just stab into the seal, get a grip and pull it out.
Once its out, clean the area, apply a light coating of grease around the new seal and tap it in evenly
Page 115 http://personal.utulsa.edu/~nathan-b...ne/69cylin.pdf
According to the manual, you can replace the seal with or without removing the seal retainer.
