1990 22re running issues
Old 07-07-2011, 07:51 AM
mark in arkansas's Avatar
Newbie. I have a 1990 4wd truck, 5 spd manual with 22re engine. I was getting a slight hesitation at high RPM's, and the check engine light flashed on. I changed oil, and fuel filter. Now, the truck bucks and backfires and will not run at all. IF I reach in and hold up the outbound fuel line, the motor smooths out. I did have a burned plug wire that I replaced. The air intake hose is tight, no leaks. It has new plugs also. It does burn oil, and has low compression in #1 cylinder.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 22re running issues
