1990 - 1995 Part Swap
Old 01-07-2010, 06:30 AM
cjlqtr's Avatar
I have a rusty 1990 3.0 4WD pickup that is a donor for my 1995 22RE 4WD pickup. Does anyone know if the cold start injector timer switch, front brake calipers, and radiator are interchangable?
Old 01-07-2010, 06:33 AM
4Crawler's Avatar
Calipers and radiator should swap. On the cold start timer, see if the connectors are the same and then see if it will physically fit and then you could look up the time/temperature specs on the two parts in a Factory Service Manual and see if they are similar.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
coryc85
09-09-2015 06:24 AM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 1990 - 1995 Part Swap
