1988 4runner problems, i think ive solved it
Old 06-17-2006, 08:23 AM
Chapman88SR5's Avatar
i have posted a couple threads not that long ago about some of my problems..
https://www.yotatech.com/forums/f116/milkeshake-1988-4runner-87354/
https://www.yotatech.com/forums/f116/transmission-problem-85551/
I believe both of these problems are related to my transmission leaking. Can it leak oil into the radiator? Also now the transmission makes a nasty noise while moving forward, just while starting out. at cruising speed i cant hear anything.
Old 06-17-2006, 08:41 AM
wrenchmonster's Avatar
Didn't you say you had a manual transmission?
In either case, if you have anything cooling through your radiator I'd start from the radiator and work backwards. Look for auxillary hoses on the bottom tank of the radiator and then follow them back. If you don't have an automatic transmission, you're more likely to have an engine oil cooler. Check all your fluids. You've got to be loosing some oil or gaining some water in something. Good luck.
Old 06-17-2006, 08:44 AM
im losing a lot of oil actually. i just had to put 2 quarts in.
i have a manual transmission
Old 06-17-2006, 08:48 AM
Have you done a compression check? Sounds like a HG. I'd suspect if it is indeed your HG then running that milky oil has ruined your bearings on the bottom end. That would also explain the load knock you're hearing when you start to take off. Sorry, for your sake I hope I'm wrong.
Old 06-17-2006, 08:54 AM
i dont hear it when i just rev the engine in nuetral. only when its in gear and im moving
Old 06-17-2006, 09:00 AM
That's because your engine is not under load. It's the same reason you don't try to do whole shots when you're pulling a trailer.
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1988 4runner problems, i think ive solved it
