1988 4 Runner 22re engine codes
On my 88 4 runner, it wouldn't pass smog. After failing i checked engine codes, and code 8 came up and code 25 came up. Looked up code 8 and it says intake air temp sensor, where is that located. Anyone else have any ideas? Should i replace oxygen sensor?
intake air temp sensor is in the air-flow meter (on top of the air filter)
check the connectors and terminals for any corrosion or condensation and make sure the terminals are firmly seated in the plugs
Well i replaced the oxygen sensor drove it on the freeway, and check engine light came on then went off, checked the codes, and code 5 came up. Not sure what to check now.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
