1987 new engine wont pull itself into driveway
Old 12-08-2013, 07:09 PM
Crazy4x4_468's Avatar
Just installed a reman 22re long block in my 1987 toyota pickup, got it all done and it has thrown code 11. I installed new tp sensor and there was no change. The pickup will barely get up to 20mph. Please help!
Old 12-08-2013, 07:24 PM
SoCal4Running's Avatar
Installing means it is adjusted correct? Can not simply bolt a new one on.
Distributor off a tooth?
Old 12-08-2013, 07:32 PM
Ryan G.'s Avatar
check timing. x2 what socal said. check firing order. is it running smooth or bucking like a bronco?
Old 12-08-2013, 07:33 PM
I haven't adjusted the tps yet, my multi meter is at work so i hafta wait till tomorrow night when i have that to adjust it but i was just looking for other ideas, but if the distributer was off a tooth would it still have seemed to time right? I have it at 5 degrees
Old 12-08-2013, 07:36 PM
Seems to run smoothly but once its under load trying to pull itself it falls on its face. Firing order is correct and have checked the timing multiple times.
Old 12-08-2013, 07:43 PM
I found on top of the valve cover towards the rear there is a little box with a electronic connecter and theres a vacuum line from the intake going into the front, then on the back there looks like there should be 2 vacuum lines but one is broke off. Does anyone know what this, where the vacuum lines run to on the back, and if this could cause the problem? I dont see any vacuum lines not hooked up so not sure about it
Old 12-08-2013, 07:53 PM
First off the TPS has to be adjusted for the engine to operate properly, there is no way around it.
The rear VSV (Vacuum Switching Valve) on my 86 goes to the fuel pressure regulator.
Old 12-08-2013, 08:05 PM
Thats what i was talking about, looks likes yours only has one line coming out the back also, must not be the problem. But yes im gonna adjust it tomorrow night, just didnt have a multimeter to do it tonight when i stuck the sensor on
Old 12-08-2013, 08:07 PM
The front VSV on mine does have 2 hoses which you can just see in the bottom of the first pic.
Old 12-08-2013, 08:19 PM
Im talking about the one towards the rear of the valve cover. In the second pic you see one vac line coming out the rear
Old 12-08-2013, 09:08 PM
I got cha. The rear VSV should only have 1 hose on each side. Vacuum from the plenum and then on the rear it should go down to the fuel pressure regulator.
The VSV with 2 outlets and 1 inlet is for the AC Idle system. The front inlet is open to atmosphere and the rear go to the idle speed adjusting knob.
Possible yours are backwards?
The top one here is actually at the middle of the valve cover.
Old 12-09-2013, 07:37 AM
Well after seeing the pictures of yours i dont believe that has anything to do with the problem, hopfully when i get the tps adjusted its fixed
Old 12-09-2013, 04:57 PM
Adjusted the tps and then checked the timing, aparently that sensor effects timing because it was way off so i retimed it and it seems to run much better
Old 12-09-2013, 08:26 PM
Thanks for everyones input, you guys were alot of help. Thanks again
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
snosurfer
3.4 Swaps
03-29-2016 11:29 AM
crashburnoveride
08-28-2015 09:20 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 1987 new engine wont pull itself into driveway
