need help with CPU Code reader
Old Feb 2, 2007 | 10:50 AM
Badkitty's Avatar
I have a 85' 4x4 22RE ,Im borrowing my friends code reader
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
i dont know where the plug in on the truck is. i dont have the owner manual but i do have a haynes auto manual in PDF, but there is no search function. can someone tell me where its at?
Old Feb 2, 2007 | 10:52 AM
Elton's Avatar
its by the fuse box cant miss it
Old Feb 2, 2007 | 10:55 AM
Elton's Avatar
if that dont work http://www.off-road.com/toyota/tech/codes/index.html
Old Feb 2, 2007 | 05:15 PM
Badkitty's Avatar
uh...i dont see any kind of plug on or anywhere near the fusebox under the dash. i looked at box under hood and dont see anywhere to plug in either. anyone with same year take a pic of its location or what it looks like
also i just noticed...i have a 22RE....should my ECU say 22RE on it ? cause it only says 22R
Old Feb 2, 2007 | 09:29 PM
toyota_mdt_tech's Avatar
On ther 1985, it will be a yellow 2 pin plug near the air cleaner. Jump the 2 pins together. There is two plugs, other is a 4 pin. Both kinda park in rubber cups on the inner fender next to the air cleaner. Jump the 2 pin, read the blinks of the check engine light.
Old Feb 2, 2007 | 10:28 PM
Badkitty's Avatar
ok i tried that but nothing happened. i guess what i figured is true. dealer i bought ttruck from disconnected engine light. either that or light is out, but i doubt that. is there no plug to connect that code reader into then ?
Old Feb 3, 2007 | 08:58 AM
Are you using the round plug or the "T" shaped one? The "T" one only powers up the fuel pump. You should of ran the round one.
Old Feb 3, 2007 | 10:01 AM
4Crawler's Avatar
See:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
The one circled in light blue:
I got my code reader at Office Depot:
Old Feb 3, 2007 | 12:07 PM
Badkitty's Avatar
are they plugged into anything ? or those rubber sockets just to hold them? cause mine were just laying around dangling.
Old Feb 3, 2007 | 12:09 PM
4Crawler's Avatar
Rubber sockets are just there to hold them, one usually has a rubber cap and the fuel pump test jumper just hangs loose. They are diagnostic plugs, only needed when doing troubleshooting. I hard wired some of mine to switches for ease of use:
Old Feb 3, 2007 | 12:25 PM
They are usually just hanging around when someone checks the air filter, knocks it our of the rubber socket. The rubber socket just keeps them tidy looking. The other member posted a perfect picture of the sockets. The large yellow 4 pin one is used to set VF learned, great to know if you ever have to calibrate a air flow meter, but of no concern to you as of yet.
Old Feb 3, 2007 | 05:12 PM
Badkitty's Avatar
ok so i pulled my gauge cluster out to check bulbs..all bulbs fine...all fuses fine both inside and in engine compartment. My check engine light never turns on. even when key turned to ON and/or IGN . nor does it blink or anythign when i jump that connector to diagnose. did you see what i asked about the ECU only having 22R written on it
Old Feb 4, 2007 | 11:50 AM
4Crawler's Avatar
Yep, they all have 22R on the ECU boxes. Maybe the ECU is bad of the CEL light is not coming on, or maybe the wires between the check connector and ECU are bad, check for continuity at the ECU connector.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
