I need a tie rod--i think ?!
i am in need of a tie rod is what i was told, but when i look at my auto repair manual, the tie rod is showing to be the end pcs to a long bar it attaches to.
the long bar that the tie rod is showing to attach to is actually what i am needing because mine is bent.
anyone know what it is called or where i can find one???
Does this help?
You bent what is referred to as the tie rod assembly?
edit; Nevermind, thought this was in the second gen forum.
if its the 'long rod' connecting the left side to the right side assemblies, there are a few names. 'relay rod', 'center link', 'drag link'. just to name a few. it would connect the tie rods left and right, idler arm, pitman arm.
Potential dumb question: I just picked up a SFA with hi steer already on it but the tie rod is bent some in the middle. Is there a tolerance that would allow me to keep it or is it a must that I replace the rod?
Like Peow said, just replace it. IMO if it is bent no way you will get it aligned.
main tie rod DOm at skys $100: http://www.sky-manufacturing.com/new...duct.php?id=62
All pro has one for $60: http://www.allprooffroad.com/pickupsteering/253
I did not see it listed separately on either T-G or Marlins site
I think the Marlinks are marlins'. I'll probably go with the all pro as its their kit to begin with that's on the axle. Plus I believe the $60 one is the just the tubing, w/o the ends.
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
JookUpVandetti
09-30-2015 08:58 AM
