Gear Oil for Tranny
Gear Oil for Tranny
Question... On my 84 truck, all the manuals call for gl-4 gear oil in the tyranny. I called the two dealers since I can't find it at the local parts stores and they told me to use gl-5 because that is what they would use. Should I just order some Redline MT-90 and be done with it? If so, does anyone have a good source for it?
Have also found conventional GL4 oil at local auto parts stores. Usually StaLube brand in a gallon jug.
Ive used 80-90w before and had hard shifting problems when col 70-90w fixed the problems they both say gl3 gl4 and gl5 compatible but their is a differance in shifting when col if you have problems might depend on mileage on tranny to
80-90 mobil 1 synthetic.. pick it up anywhere works fine
i use dino valvoline in my tranny/case/axles ive run synethetic thru my transmissions before and others ... its all mental to me
Iceman4193
07-15-2015 04:48 PM
Jnkml
07-06-2015 01:20 PM
