front driveshaft question
Old Nov 12, 2007 | 10:18 AM
scmedic's Avatar
I've noticed my front driveshaft spins when I drive even though the transfer case and manual hubs are disengaged. Just curious does anyone know why this happens? Is this normal or does it indicate a problem?
BTW, I'm pretty sure everything is disengaged because I can turn the driveshaft by hand when the truck is stopped & I know the driveshaft is spinning because I get fresh grease splatter around the spline and the U joint...
Old Nov 12, 2007 | 10:21 AM
4Crawler's Avatar
Can sometimes spin due to the drag of the heavy gear oil on the front drive gears. May do it only when the oil is cold (thicker) and stop when it heats up (gets thinner then).
88sasturbotoy
Jan 30, 2026 01:57 PM
kazuya2416
Apr 5, 2024 02:17 AM
oldirtydirt
Feb 23, 2020 09:30 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
icentropy
Jul 14, 2015 10:23 AM
