| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
engine running great. exhaust smells very rich?
#2 (permalink) |
Getting a smog test would tell you what gasses are being released in excess and would help narrow down the area of problem.
#3 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Knowing whether you're carb'd or EFI would help to.
__________________
Quote:
Insomnia: it's a way of life.
#4 (permalink) |
oh yeah. The truck is 1985 pick up 22r, carb'd. Going to run 'guaranteed to pass formula' through it and have smog test done this week. I have a strong feeling it is going to fail. The smell is ridiculous.
#5 (permalink) | ||
I would have the smog test done without the guaranteed to pass... at least that way you can get a good reading and troubleshoot accurately from there.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 233k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 235k on the clock. It's becoming an addiction. |
#6 (permalink) |
Carb out of adjustment? Not using OEM or NGK plugs? Valves not Properly adjusted? Airfilter dirty?
__________________
My current: 1986 Toyota 4runner SR5 EFI 4cyl 2.4L 22RE 5-Speed 242,000 Miles 95% Stock __________________ (Still working on restoring her) My old: 1988 Toyota 4runner SR5 EFI V6 3.0L 3VZ-E 5-Speed 302,000 Miles All stock (sold)______________ (Was my fastest truck i miss her...) My old: 1989 Toyota 4runner Non-SR5 EFI 4cyl 2.4L 22RE Automatic 231,000 Miles (sold)______________ (was my quietest and slowest yota.) |
#7 (permalink) |
I agree with Team420 about not using the guarantee formula, this is only a temporary solution and not the answer. You might need a new cat every two years due to the original problem. Get the readings and post. If you have the old readings from the last smog check post them too.
#8 (permalink) | |
That pass in a can only works if you're close to the maximum limits not way over. Don't use it. Its expensive and hard to get your $$ back. Go to a pass or don't pay smog shop.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
#9 (permalink) | |
Quote:
there ya go abe...i just wanted to point that out..LMFAO ![]() ![]() ![]()
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
| Tags |
| 04, 1985, 22, 22re, 4runner, bad, exhaust, headache, problem, rich, run, smell, smells, strong, toyota |
